JabberGuest Sandbox with Android CallSample
gordonlee-mpel
I've reserved a Jabber Guest lab to do the testing, and followed the step of Jabber Guest Sandbox Lab and completed the testing successfully.
https://devnetsandbox.cisco.com/Docs/JabberGuest/JabberGuest.pdf
And now, I am going to deploy the CallSample (which is come from the Jabber Guest Android SDK) to my Android device, and try to connect to the Jabber Guest Sandbox.
However, when I run the CallSample and click the "Call" button in my device, it keeps on throw the below error:
WARN  [0xaec85f80] [cpve/src/main/ConnectionFactory.cpp(393)] [cpve] [on_port_allocated] - -1 is not a valid connection.
ERROR [0xb491d380] [cpve/src/main/ConnectionFactory.cpp(366)] [cpve] [waitForReady] - Exiting. Returning false : Port allocation failed, a port could not be allocated.
ERROR [0xb491d380] [cpve/src/main/ConnectionFactory.cpp(746)] [cpve] [waitForPortFreed] - Failed to wait for conn_id -1 free to finish.
In the CallSample apps, I connect to the Jabber Guest Sandbox with the following parameter:
DEFAULT_SERVER = "jabberguest.abc.inc"
DEFAULT_ADDRESS = "1001@10.10.20.1"
Is there any setting need to do in the JabberGuest Server?
Or is it due to incorrect DEFAULT_SERVER and DEFAULT_ADDRESS?
Gordon
0 Replies 0
