Using bluetooth headset to answer calls in jabber for mac
Emiliwoe
Hi all,
Hope i post this question on the right page;
I have a question regarding jabber for mac. My colleague has mac mini and uses a jabra headset for answering calls on jabber. Most of the time he logs in on a terminal server and when he gets a call it doesn't pop up over his screen. The ideal solution would be that he can answer the call with the button on his headset.
I know there is a script for skype users on mac that the button can 'hotkey' with the mac so you can answer calls with the headset button. Is there also a script for mac? Its a certified jabra headset.
Thanks!
Greets,
Emile
dstaudt
I don't believe there is any facility/API on Mac for integrating a headset with the Jabber client (for Windows, there is an SDK for such integrations.)
Per Jabra's site, it appears to show 'audio only' for Jabber Mac:
Cisco Phone Headsets | Jabra
dstaudt
thank you for the reply and the information. i fully understand
I think i'm going to make an android profile for his phone so he can use jabber on his phone to pickup calls with his headset.
Thanks again!
