3rd party sip registration - 4331 Router - IOS 16.4.1
mikecooley
I'm attempting to register a third party SIP device to the 4331 Router running in CME mode.   This process has worked for years on a 2901 router, and originally worked on the 4331 router running IOS 3.16.04.   Once I upgraded to 16.4.1, the registration request is successfully challenged with a 401 Unauthorized, but returns a 404 Not Found after the registration attempt with the proper credentials.
Is there a new setting in the firmware that is preventing the registration process?     Below, I have included a generic version of the config file in the manner that I'm attempting to use.   I also attached a "debug ccsip all" for an example registration attempt where it shows a "No matching pool for this REGISTER contact - 1111@192.168.11.34".
Also, if I run a "show voice register all", it shows the registrations attempts under the "VOICE REGISTER GLOBAL" statistics, but shows 0 attempts under the "VOICE REGISTER POOL" statistics.
Any help, suggestions or pointers would be appreciated.
voice service voip
no ip address trusted authenticate
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server
voice register global
mode cme
max-dn 8
max-pool 8
authenticate register
authenticate realm all
auto-register
voice register dn  1
number 1111
name Registration-1
voice register pool  1
id mac 0000.0000.0000
number 1 dn 1
dtmf-relay rtp-nte
username 1111 password test
voice-port 0/1/0
timeouts ringing infinity
timing hookflash-out 500
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
caller-id enable
telephony-service
timeouts ringing 60000
max-conferences 8 gain -6
transfer-system full-consult
dial-peer voice 1 pots
destination-pattern .
port 0/1/0
sip-ua
timers expires 1800000
6 Replies 6
Raghavendra G V
Hi Michael,
Please contact cisco TAC for sip registration issue, they should be able to help you.
Raghavendra
Thank you for the response. However, I had already opened a TAC request, and was told that third party SIP registrations were not officially supported on CME, thus TAC could not offer support.
Hi Michael,
I am sorry, this forum for TCL IVR script issues.
Raghavendra
Bryce Palmer
Just in case someone stumbles across this dead thread in the future (like I did).  The way to make this work is to change
number 1 dn 1
dtmf-relay rtp-nte
to
id device-id-name 1111
number 1 dn 1
dtmf-relay rtp-nte
Hi Bryce,
Thank you! After Friday-->Sunday evening boiling my brain I've found your post.
changing " id mac 0001.0001.0001" to "id device-id-name 2000" have saved me from going insane.
THANK YOU!!!
Thanks a lot!!!
