Convert History-Info to Diversion Header
We have CUCM 8.6 cluster integrated with Microsoft Lync over SIP Trunk.
We have the below SIP Normalization script to convert the History-Info to Diversion Header,
M = {}
M.allowHeaders = {"History-Info"}
function M.inbound_INVITE(msg)
msg:convertHIToDiversion()
end
return M
When a Lync user sets Call Forward All & Call Forward No Answer to external number, the script correctly changes the the header.
However when the same Lync user sets Simultaneous ring on the client, CUCM does receive the same History-Info but without any reason text.
Hence the script is not taking effect on that received INVITE message.
When we did Call Forward All from Lync number:+16477900399 to +13365439382, below is the History Info we received and it was converted to Diversion Header
HISTORY-INFO: <sip:+16477900399@uswsnn230.vcnqalab.dsqalab.volvo.net;user=phone?Reason=SIP%3Bcause%3D302%3Btext%3D%22Moved%20Temporarily%22>;index=1;ms-retarget-reason=forwarding,<sip:+13365439382@uswsnn230.vcnqalab.dsqalab.volvo.net;user=phone>;index=1.1
But when we did simultaneous ring to +13365439382 and got the following HISTORY-INFO, it was not converted to Diversion Header by the same script
HISTORY-INFO: <sip:+16477900399@uswsnn230.vcnqalab.dsqalab.volvo.net;user=phone>;index=1;ms-retarget-reason=forwarding,<sip:+13365439382@uswsnn230.vcnqalab.dsqalab.volvo.net;user=phone>;index=1.1
The only difference I see the in those 2 History Info is that, Simultaneous Ring INVITE doesn't have the reason text included.
is that the reason the Script not converting the header?
Thanks for your help
Suresh
//Suresh Please rate all the useful posts.
10 Replies 10
Hi, I managed to fix the issue by following the below video guide from Sreekanth. It is a very useful one if anyone likes to write the sip normalization scripts.
https://supportforums.cisco.com/node/12151771
BR,
Suresh
I have same issue when I receive  diffent incoming sip trunk (Lync and Siemens HiPath)
I could not see diversion header  on the CUBE  (lync trunk and QSIG  incoming calls.)
Call Flow for Lync:
Lync-SIP Trunk-sip-CUCM--SIP sip-CUBE-sip--ISP
QSIG Call Flow:
Siemens HiPath--QSIG / PRI-E1-VG 2921-sip--CUCM- sip-CUBE---sip- ISP
I can able to see Diversion header for my cisco iphone when i enable diversion redirected CSS on CUBE Sip trunk
Sorry, I'm not sure what you are seeing... Neither History-Info or Diversion?
I could not see any diversion and history info on the QSIG gateway .
Do you have a working scnerio ?
It's working as well CUCM initiated call fine but if call generated from QSIG gateway
Siemens HiPath 4000  does not sending history info or diversion , Its very old pbx system.
There are a couple of commands to make sure that history-info gets placed in INVITE. Have a look at these documents to get you started:
Cisco Unified Border Element SIP Support Configuration Guide, Cisco IOS Release 15M&T - SIP History INFO [Cisco Unified…
How voice gateway understand sip history received by Siemens Hipath 4000 ?
i found on this page 1 and 2 is that correct solution ?
When I enabled it on voice services voip  or dial-peer level Does voice gateway generate sip history info ? otomaticaly but how voice gateway know calls are forwarded or not forwarded ?
http://www.cisco.com/c/en/us/td/docs/ios/ios_xe/voice_cube_-_ent/configuration/guide/vb_10566_xe.pdf
If there is a 'redirecting number' IE (information element) in the Q.931/Q.sig SETUP message, these commands should convert that information into SIP headers.
These commands have to be configure through the Gateway (IOS) CLI, you can't apply them through Unified CM. I'd recommend opening a TAC case for assistance as this is not specifically a developer task.
Mark
Are you mentioned Display i = 'user01'  on your previous post ?
I thing configuration should be as follow,
1)
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn outgoing display-ie
no cdp enable
2)
no ip address
encapsulation hdlc
isdn outgoing ie display
no cdp enable
Nov 23 12:36:11.610: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8  callref = 0x00A3
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98383
                Exclusive, Channel 3
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x4180, '2023001'
                Plan:ISDN, Type:Subscriber(local)
        Called Party Number i = 0xC1, '3023001'
Nov 23 12:36:11.642: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x80A3
Nov 23 12:36:11.694: ISDN Se0/2/0:23 Q931: RX <- ALERTING pd = 8  callref = 0x80A3
        Progress Ind i = 0x8188 - In-band info or appropriate now available
