Get Address through Specific Terminal by using Jtapi?
zain.iftikhar
I'm new with Jtapi. We get addresses and terminals through jtapi library by using following method(  provider.getAddresses(); provider.getTerminals(); ).
My question is that can we get address of specific user through jtapi.
Like I will give terminal (John) and get back address of that terminal (20001).
pmnkumar
Terminal.getAddresses() will return all the addresses configured on that terminal. There is no easy way to get the Terminal for a particular user unless extension mobility is active on the device. If there is a active EM login session on the phone, getEMLoginUsername() will return the userid. You need to loop through all the terminals to find a match and works if all the users do EM.
AXL API is more appropriate to find the user<->phone configuration.
