Get CTI calls events
samba.thibo
My need is simple and couldn't get any information/solution from the support
From a web based application, I would like to get all calls events from a specific phone number.
I want to know:
- who is calling
- who picked up the phone
- how long last the call
- etc.
I didn't succeed to get a sample code from this site.
Can someone help me out?!
Thanks folks
Samba
Geevarghese Cheria
Hi Samba,
   You can login and will be able to download the sample codes from here - Cisco UCXAPI
Thanks and Regards,
Geevarghese
Geevarghese Cheria
Hi Samba,
Thanks and Regards,
Geevarghese
Hi Geevarghese,
I tried to implement this solution but my company adminsitrator told me that they are not using a CME router, the example you gave me won't work
He told me to connect directly to the UCCX database and run queries every 2 seconds to get live data.
I'm not thrilled about this solution since a lot of calls will be made against the database...
In addition, I don't know where to find live incoming call from a user to the call center?
Any ideas?
Samba
