How to get notification of RTP streams
aklassen
I have added address/call/terminal observers successfully to monitor calls and I receive
RTP started/stopped events successfully for audio streams. However, when I use a phone with video
capabilities which has booth voice and video, I am still only receiving the RTP events for the
audio portion.
How do I enable notifications for video as well?
Andrew
7 Replies 7
mpotluri
Level 5
Level 5
Andrew,
    You need to turn on the terminal filter preferably before adding the terminal observer. Check setMultiMediaStreamsInfoEvFilter(true) interface in CiscoTermEvFiler.  Cisco JTAPI Java Doc or developer guide will have more info.
After turning on this filter, application should start seeing CiscoMultiMediaStreamsInfoEv which has all the info. HTH
Hi Mohan,
Not sure what I am doing wrong but I am not receiving this event. Assuming I will receive the event
as part of the terminalChangedEvent handler. Do I need to enable anything special for the application?
I looked and did not see anything obvious. In my setup I have Standard CTI enabled, Allow call monitoring and
allow control of all devices.
Thanks for the help,
Andrew
Hi Andrew,
   Are you seeing video on the phone? i don't think there is any other config required for this other than the filter. JTAPI log might give some clues. Can you attach JTAPI logs from the app start time?
Hi Mohan,
I do see video on the phones. I enabled everything and the log file is about 5000 lines long. I don't see a way to attach a file. Is there any portion(s) in particular that I can paste for you to look at?
I am expecting to receive the event as part of the terminal observer which I have declared as extending CiscoTerminalObserver. I also have code to handle the event under the call observer which extends CallObserver CallControlCallObserver and MediaCallObserver.
Andrew
When you add observer on the Terminal, you will see a DeviceOpenRequest to CTIManager and it contains a list of flags. Make sure that MultiMedia filter (bMultiMediaStreamsInfo) is turned on.
When video is established on phone, we should see MultiMediaStreamsInfoEvent  in the logs.
You should find these in JTAPI logs if tracing is set to detailed level.
Hi Mohan,
I do see the following line for the two devices' open requests:
252: May 30 13:52:52.995 CDT %JTAPI-PROTOCOL-7-UNK:(P1-192.168.21.119) [main] sending: com.cisco.cti.protocol.DeviceOpenRequest {
  sequenceNumber        = 8
  deviceName            = SEPCCEF488D4DBC
  filter                = com.cisco.cti.protocol.DeviceEventFilter {
  deviceModeChanged               = false
  keyPressed                      = false
  featureButtonPressed            = false
  lampModeChanged                 = false
  ringModeChanged                 = false
  displayChanged                  = false
  startTransmission               = true
  stopTransmission                = true
  startReception                  = true
  stopReception                   = true
  softKeyPressed                  = false
  openLogicalChannel              = false
  deviceData                      = false
  mediaResourceAllocated          = false
  mediaResourceDeallocated        = false
  mediaResourceUpdated            = false
  mediaConnectionAdded            = false
  mediaConnectionRemoved          = false
  mediaResourceExisting           = false
  existingMediaResourcesCompleted = false
  snapshot                        = false
  receptionKey                    = false
  transmissionKey                 = false
  deviceIdleState                 = false
  deviceActiveState               = false
  deviceAlertingState             = false
  deviceHoldState                 = false
  deviceWhisperState              = false
  bDNDChanged                     = true
  bDNDOptionChanged               = false
  bOpenMediaIPPortEvent           = false
  bMultiMediaStreamsInfo          = true
  softkeysApplicationId = 0
253: May 30 13:52:52.996 CDT %JTAPI-MISC-7-UNK:ObserverThread(com.nectar.ucd.cti.CtiMain$MyAddressObserver@1389c036) starting up...
254: May 30 13:52:52.996 CDT %JTAPI-PROTOCOL-7-UNK:(P1-192.168.21.119) received Response: com.cisco.cti.protocol.DeviceOpenResponse {
  sequenceNumber = 8
  result         = 0
  callManagerID  = 1
  deviceID       = 124
370: May 30 13:52:53.019 CDT %JTAPI-PROTOCOL-7-UNK:(P1-192.168.21.119) [main] sending: com.cisco.cti.protocol.DeviceOpenRequest {
  sequenceNumber        = 16
  deviceName            = SEPCCEF488D56B2
  keyPressed                      = false
  deviceData                      = false
  snapshot                        = false
  bDNDChanged                     = true
371: May 30 13:52:53.019 CDT %JTAPI-JTAPIIMPL-7-UNK:[com.nectar.ucd.cti.CtiMain$MyTerminalObserver@67ecd78]delivering to terminalChangedEvent
372: May 30 13:52:53.019 CDT %JTAPI-MISC-7-UNK:ObserverThread(com.nectar.ucd.cti.CtiMain$MyAddressObserver@1b1756a4) starting up...
373: May 30 13:52:53.020 CDT %JTAPI-JTAPIIMPL-7-UNK:[com.nectar.ucd.cti.CtiMain$MyTerminalObserver@67ecd78]ObserverProxy.deliverEvents() completed
374: May 30 13:52:53.021 CDT %JTAPI-PROTOCOL-7-UNK:(P1-192.168.21.119) received Response: com.cisco.cti.protocol.DeviceOpenResponse {
  sequenceNumber = 16
  result         = 0
  callManagerID  = 1
  deviceID       = 128
When I make the call I see the RTP Start Events in the log but I do not see the StreamsInfoEv.
905: May 30 14:00:14.418 CDT %JTAPI-PROTOCOL-7-UNK:(P1-192.168.21.119) received Event: com.cisco.cti.protocol.StartTransmissionEvent {
  eventSequence          = 41
  deviceCallManagerID    = 1
  deviceID               = 128
  callCallManagerID      = 1
  callLegID              = 19804517
  ipAddr                 = 905972746
  rtpPortNumber          = 22256
  milliSecondPacketSize  = 20
  compressionType        = 4
  precedenceValue        = 136
  useSilenceSuppression  = false
  maxFramesPerPacket     = 80
  bitRate                = 1
  mediaDeviceName        =
  mediaResourceId        = 0
  mediaConnectionMode    = 3
  rtpDest_v6             = com.cisco.cti.protocol.RTPDestinationV6 {
  ipAddr_v6  = null
  rtpPort_v6 = 0
  activeIpAddressingMode = 0
906: May 30 14:00:14.418 CDT %JTAPI-MISC-7-UNK:(P1-192.168.21.119) EventThread: queuing com.cisco.cti.protocol.StartTransmissionEvent
907: May 30 14:00:14.419 CDT %JTAPI-JTAPI-7-UNK:(P1-ucdcti) [SEPCCEF488D4DBC] CiscoRTPInputStartedEv [#64] Cause:100 CallCtlCause:0 CiscoCause:0 FeatReason:12
I do see an event which indicates both devices have Multimedia Capabilities.
756: May 30 14:00:12.351 CDT %JTAPI-JTAPIIMPL-7-UNK:{(P1-ucdcti) GCID=(1,138)->ACTIVE} CallManager.processCallStateChange:Handling STATE_PROCEEDING for 1004:SFBPartition:1
757: May 30 14:00:12.351 CDT %JTAPI-PROTOCOL-7-UNK:(P1-192.168.21.119) received Event: com.cisco.cti.protocol.NewCallEvent {
  eventSequence                        = 31
  lineCallManagerID                    = 1
  lineID                               = 128
  lineHandleSpecified                  = true
  globalCallManagerID                  = 1
  callID                               = 138
  callingParty                         = 1004
  calledParty                          = 1006
  originalCalledParty                  = 1006
  state                                = 2
  origin                               = 1
  userData                             = null
  auxiliaryData                        = 1
  farEndpointCallManagerID             = 1
  farEndpointType                      = 1
  reason                               = 1
  callingPartyName                     =
  calledPartyName                      = USER 6
  originalPartyName                    = USER 6
  lastRedirectingParty                 =
  lastRedirectingPartyName             =
  callingPartyDeviceName               = SEPCCEF488D4DBC
  bRemoteInUse                         = false
  parentCallManagerID                  = 0
  parentCallID                         = 0
  bPrivacy                             = false
  mediaDeviceName                      =
  mediaResourceId                      = 0
  unModifiedCallingParty               = 1004
  unModifiedCalledParty                = 1006
  unModifiedOriginalCalledParty        = 1006
  unModifiedLastRedirectingParty       =
  callingPartyPi                       = true
  callingPartyNamePi                   = true
  calledPartyPi                        = true
  calledPartyNamePi                    = true
  originalCalledPartyPi                = true
  originalCalledPartyNamePi            = true
  lastRedirectingPartyPi               = true
  lastRedirectingPartyNamePi           = true
  unicodeCallingPartyName              = com.cisco.cti.protocol.UnicodeString {
  unicodedisplayName =
  count              = 0
  sizeofElement      = 2
  unicodeCalledPartyName               = com.cisco.cti.protocol.UnicodeString {
  unicodedisplayName = USER 6
  count              = 6
  sizeofElement      = 2
  unicodeOriginalCalledPartyName       = com.cisco.cti.protocol.UnicodeString {
  count              = 6
  sizeofElement      = 2
  unicodelastRedirectingPartyName      = com.cisco.cti.protocol.UnicodeString {
  count              = 0
  sizeofElement      = 2
  unicodeCallingPartyLocale            = 1
  unicodeCalledPartyLocale             = 1
  unicodeOriginalCalledPartyLocale     = 1
  unicodeLastRedirectingPartyLocale    = 1
  callingPartyDNInfo                   = com.cisco.cti.protocol.PartyDNInfo {
  sipUrl           = com.cisco.cti.protocol.SIPUrl {
  user         =
  host         =
  port         = 0
  transportTye = 0
  urlType      = 0
  unModifiedsipUrl = com.cisco.cti.protocol.SIPUrl {
  user         =
  host         =
  port         = 0
  transportTye = 0
  urlType      = 0
  partition        = SFBPartition
  voiceMailbox     =
  numberType       = 0
  calledPartyDNInfo                    = com.cisco.cti.protocol.PartyDNInfo {
  user         =
  host         =
  port         = 0
  transportTye = 0
  urlType      = 0
  user         =
  host         =
  port         = 0
  transportTye = 0
  urlType      = 0
  partition        =
  voiceMailbox     =
  numberType       = 0
  originalCalledPartyDNInfo            = com.cisco.cti.protocol.PartyDNInfo {
  user         =
  host         =
  port         = 0
  transportTye = 0
  urlType      = 0
  user         =
  host         =
  port         = 0
  transportTye = 0
  urlType      = 0
  partition        =
  voiceMailbox     =
  numberType       = 0
  lastRedirectingPartyDNInfo           = com.cisco.cti.protocol.PartyDNInfo {
  user         =
  host         =
  port         = 0
  transportTye = 0
  urlType      = 0
  user         =
  host         =
  port         = 0
  transportTye = 0
  urlType      = 0
  partition        =
  voiceMailbox     =
  numberType       = 0
  ctiCallType                          = 0
  callingPartyIpAddr                   = 905972746
  farEndLineIdDN                       = 1004
  farEndLineIdPartition                = SFBPartition
  callPresentable                      = true
  featurePriority                      = 1
  globalizedCallingParty               = 1004
  callingPartyIpAddr_v6                = null
  callingPartyIpAddressingMode         = 0
  bIsRolloverCall                      = false
  uniqueProtocolCallReference          = 000000000000008A012E316500000000
  cgpnHuntMemberDN                     =
  cgpnHuntMemberPartition              =
  cgpnPatternUsage                     = 2
  cdpnPatternUsage                     = 2
  callingPartyMultiMediaCapBitMask     = 3
  calledPartyMultiMediaCapBitMask      = 3
  callingPartyMultiMediaCapabilityInfo = com.cisco.cti.protocol.DeviceMultiMediaCapability {
  videoCapability  = 1
  telepresenceInfo = 0
  screenCount      = 0
  calledPartyMultiMediaCapabilityInfo  = com.cisco.cti.protocol.DeviceMultiMediaCapability {
  videoCapability  = 1
  screenCount      = 0
758: May 30 14:00:12.351 CDT %JTAPI-MISC-7-UNK:(P1-192.168.21.119) EventThread: queuing com.cisco.cti.protocol.NewCallEvent
759: May 30 14:00:12.351 CDT %JTAPI-JTAPIIMPL-7-UNK: ProviderImpl.findExternalAddress creating new address for 1006 type 4
760: May 30 14:00:12.352 CDT %JTAPI-JTAPI-7-UNK:Adding reference to external addresses 1006 in partition  addrType 4 in hashtable
761: May 30 14:00:12.352 CDT %JTAPI-PROTOCOL-7-UNK:(P1-192.168.21.119) received Event: com.cisco.cti.protocol.CallStateChangedEvent_V2 {
Andrew
Just want to respond to this thread to what the issue was. In my case, the video phone was configured with SCCP protocol.
I saw a note in the developer guide that the phone needed to be SIP mode. I migrated the phone and now I get the
events.
Thanks for all the help,
Andrew
