04-08-2016 07:23 AM
Hi Everyone,
We have a customer that mistakenly associated a logout profile with a device with no lines configured. As shown in the attached jtapi log this resulted in an DeviceLineInfoEvent error followed by a NullPointerException. It appears that this one device problem then causes the entire provider to go out of service.
Cisco Jtapi version 8.6(2.10000)-2 Release.
Thank you,
Derrick
Here is the the problem:
11217: Apr 08 03:58:36.932 EST %JTAPI-PROTOCOL-7-UNK:(P1-58.162.162.112)Error with DeviceLineInfoEvent received for device: SEP500604732F73 with error: -1932787712
11218: Apr 08 03:58:36.932 EST %JTAPI-MISC-7-UNK:(P1-58.162.162.112) EventThread: queuing com.cisco.cti.protocol.ProviderGetSingleDeviceAndLinesCompletedEvent
11219: Apr 08 03:58:36.936 EST %JTAPI-CTIIMPL-7-UNK:(P1-58.162.162.112) caught java.lang.NullPointerException
at com.cisco.cti.client.implementation.Provider.handleEvent(Provider.java:2900)
at com.cisco.cti.client.implementation.Provider$EventThread.messageReceived(Provider.java:610)
at com.cisco.cti.util.MessageThread.deliver(MessageThread.java:358)
at com.cisco.cti.util.MessageThread.deliverAll(MessageThread.java:327)
at com.cisco.cti.util.MessageThread.run(MessageThread.java:282)
11220: Apr 08 03:58:36.936 EST %JTAPI-CTIIMPL-7-UNK:(P1-58.162.162.112) EventThread handling event com.cisco.cti.protocol.ProviderGetSingleDeviceAndLinesCompletedEvent[969]
11221: Apr 08 03:58:36.936 EST %JTAPI-PROTOCOL-7-UNK:(P1-58.162.162.112) Received ProviderGetSingleDeviceAndLinesCompletedEvent
11222: Apr 08 03:58:36.936 EST %JTAPI-PROTOCOL-7-UNK:(P1-58.162.162.112) received Event: com.cisco.cti.protocol.ProviderOutOfServiceEvent {
eventSequence = 970
PROVIDER_OUT_OF_SERVICE_EVENT = 200
11223: Apr 08 03:58:36.937 EST %JTAPI-MISC-7-UNK:(P1-58.162.162.112) EventThread: queuing com.cisco.cti.protocol.ProviderOutOfServiceEvent
Solved! Go to Solution.
04-14-2016 09:42 AM
Attached log ends at Apr 08 03:58:35.690 EST just before the snippet mentioned in this thread. During the initialization if JTAPI is unable to create a Terminal correctly it would bail and restart the initialization process. The initialization process is changed/optimized in CUCM 9.0 and we should not see this issue.
04-13-2016 07:08 PM
Any ideas? Thanks!
04-14-2016 09:42 AM
04-14-2016 10:35 AM
Thanks Mohan. That answers my question. I attached the correct jtapi log as jtapi.zip.
