10-29-2014 09:28 AM
Time ago I reported that in any IOS version after 15.1 it was not possible anymore to retrieve DNIS when the script is started via ev_handoff.
Now I find that accessing the infotag that is supposed to return this information cause the router to crash. This is with 15.2(4)M7, a version branded ED and with a star badge. The problem is 100 % reproducible with the following script and configuration.
proc handoff {} {puts "dnis [infotag get evt_handoff dnis]"}
set fsm(INIT,ev_handoff) "setup same_state"
fsm define fsm INIT
dial-peer voice 1 voip
service test out-bound
session target loopback:rtp
Attached crashfile in case anyone from Cisco wants to do something about it.
Solved! Go to Solution.
10-30-2014 12:17 AM
I think you are hitting the bug (CSCuq34654) which is fixed recently.
Raghavendra
10-30-2014 12:17 AM
Raghavendra
10-30-2014 05:55 AM
Does't show fixes in 15.2 or 15.3 ?
What Cisco will do about ?
Known Fixed Releases: | (8) |
15.4(3)S0.5
15.5(0.17)T
15.5(0.18)S0.3
15.5(0.20)PI27a
15.5(0.20)PI27b
15.5(1.1)S
15.5(1.2.1a)GB
10-30-2014 11:49 PM
Fix will not be available in 15.2 or 15.3 but will be released in 15.4 and later versions.
Raghavendra
11-03-2014 03:28 PM
Why not in 15.2 or 15.3 ? Customers wanting to use an MD release have to suffer bugs? It's actually a crash, not "moderate".
11-03-2014 11:21 PM
I think crash happened because of using the infotag command, this is fixed in later releases.
please check with fixed releases and see your issue is resolved.
Raghavendra
11-08-2014 01:01 PM
It appears to be working in 15.4(3)M1
Very bad to not have fixes for other versions that are "Cisco Suggested release based on software quality, stability and longevity."
