TCL example its-CISCO issue
jvazquez
Hello i trying to use example its-CISCO and i getting next error .. any idea ??? general configure information below error
thanks in advence
*Feb 25 19:38:36.547: //187//TCL :/tcl_PutsObjCmd: proc act_Setup
proc init_perCallvars
*Feb 25 19:38:36.551:
*Feb 25 19:38:36.551: //187//TCL :/tcl_PutsObjCmd:
ANI sip:30110@172.20.5.22
DNIS sip:5555@172.20.5.30:5060
*Feb 25 19:38:36.551: //-1//AFW_:/AFW_Util_GetUsrContainerData: Container is present, No data
*Feb 25 19:38:36.551: //-1//AFW_:/AFW_Util_CopyLegServiceCodeToCallInfoContainer: Service Code not available on Leg
*Feb 25 19:38:36.551: //-1//AFW_:/AFW_Util_CopyLegRouteCodeToCallInfoContainer: Route Code not available on Leg
*Feb 25 19:38:36.551: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not  found for tag(56)
*Feb 25 19:38:36.555: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
*Feb 25 19:38:36.559: //187//TCL :/tcl_PutsObjCmd:
Call failed.  Play prompt and collect digit
*Feb 25 19:38:36.563: //187//TCL :/tcl_PutsObjCmd:
proc act_Select
proc act_DestBusy
*Feb 25 19:38:36.567: //187/EC1D68000000/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
SIP: (187) Group (a= group line) attribute, level 65535 instance 1 not found.
SIP: Attribute mid, level 1 instance 1 not found.
*Feb 25 19:38:36.587: //187/EC1D68000000/SIP/Error/sipSPIProcessAckMedia: Could not modify QoS params for midca
service test its-CISCO.tcl
  paramspace english index 1
  paramspace english lenguage en
  paramspace english location flash:
  param aa-pilot 5555
  param operator 9998
dial peer
dial-peer voice 5555 voip
service test
session protocol sipv2
incoming called-number 5555
dtmf-relay rtp-nte
codec g711ulaw
no vad
GW version 151-4.M10
Here is the issue:
After certain version of IOS, infortag (dnis [infotag get leg_dnis]) is not returning number only, it returns above.
Solution is to extract the number or use new command.
Pleas see the following post
New Tcl IVR command option for "infotag get leg_dnis" and "infotag get leg_ani"
17 Replies 17
yawming
The sample script is not a ready to run you may need to modify according you the network environment.
There are several versions of that script, can you please attach the script you have ?
Thanks !
thanks,
this is the scrip that im using
# Script Locked by: khom
# Script Version: 2.0.2.0
# Script Name: its_CISCO
# Script Lock Date: Wed Jul  2 09:22:04 2003
# November 27, 2001, Satish Ananthanarayana (sanantha@cisco.com)
# Modification History:
# May 20, 2008, Jasmine Kalaiselvan (jkalaise@cisco.com)
# Modified the script to do leg setup and then handovers the call
# to Default IOS app. DDTS for this change: CSCsq35953 CSCsl08148
# Copyright (c) 2001 by cisco Systems, Inc.
# All rights reserved.
# Description:
#       This is a TCL IVR script for the IOS Telephony Service and
#       Call Manager (CM) offload scenario. The IVR script plays a
#       welcome prompt to the user and prompts the user to enter a
#       destination number when the user dials the auto-attendant number
#       (aa-pilot configured in the CLI). The script collects the digits that
#       the user has entered and hands the call to the enhanced session
#       application (named Default).  The session application
#       returns once there is a disconnect (if the call is established)
#       or if a call setup problem occurs.
#       The operator support is also included, if the user does not dial
#       any number or enters "0" the user will be transfered to an operator
#       (if operator number is configured in the CLI). If the user enters
#       an invalid number, the user will be prompted again to re-enter
#       the number for upto 3 times before disconnecting the call.
proc init { } {
    global param1
    global selectCnt
    global callInfo
    global legConnected
    global maxExtensionLen
    set param1(interruptPrompt) true
    set param1(abortKey) *
    set param1(terminationKey) #
    set selectCnt 0
    set legConnected false
proc init_ConfigVars { } {
    global destination
    global aaPilot
    global oprtr
# aa-pilot is the IVR number configured on the gateway to be used by the customer
# operator is the operator number for assisted calling
    if [infotag get cfg_avpair_exists aa-pilot] {
        set aaPilot [string trim [infotag get cfg_avpair aa-pilot]]
    } else {
        set aaPilot "NONE"
    if [infotag get cfg_avpair_exists operator] {
        set oprtr [string trim [infotag get cfg_avpair operator]]
    } else {
        set oprtr "NONE"
    if [infotag get cfg_avpair_exists max-extension-length] {
      set maxExtensionLen [string trim [infotag get cfg_avpair max-extension-length]]
      if { $maxExtensionLen < 0 } {
          call close
    } else {
        set maxExtensionLen 5
proc init_perCallVars { } {
    puts "\nproc init_perCallvars"
    global ani
    global digit_enabled
    global fcnt
    global retrycnt
    global dnis
    set fcnt 0
    set retrycnt 6
    set ani ""
    set dnis ""
    set digit_enabled "FALSE"
    set ani [infotag get leg_ani]
    puts "\nANI $ani"
    set dnis [infotag get leg_dnis]
    puts "\nDNIS $dnis"
proc act_Setup { } {
    global param1
    global selectCnt
    global dest
    global beep
    global callInfo
    global dnis
    global fcnt
    global aaPilot
    global oprtr
    global busyPrompt
    global legConnected
    puts "proc act_Setup"
    set busyPrompt _dest_unreachable.au
    set beep 0
    init_perCallVars
    infotag set med_language 1
    if { ($dnis == "") || ($dnis == $aaPilot) } {
        leg setupack leg_incoming
        leg proceeding leg_incoming
        leg connect leg_incoming
        set legConnected true
        puts "\nNo DNIS\n"
        set param1(dialPlan) true
        leg collectdigits leg_incoming param1
        media play leg_incoming _welcome.au %s1000 _enter_dest.au
    } else {
        set fcnt 6
        #handoff callappl leg_incoming default "DESTINATION=$dnis"
        set callInfo(alertTime) 30
        leg setup $dnis callInfo leg_incoming
        fsm setstate HANDOFF
proc act_GotDest { } {
    global dest
    global destExtLen
    global callInfo
    global oprtr
    global busyPrompt
    puts "\n proc act_GotDest"
    set status [infotag get evt_status]
puts "\n STATUS: $status"
puts "\n MAXEXTENSION: $maxExtensionLen"
    if {  ($status == "cd_004") } {
        set dest [infotag get evt_dcdigits]
        set destExtLen [string length $dest]
puts "\n DESTLEN: $destExtLen"
      set extLength [expr $maxExtensionLen - $destExtLen]
        if { $dest == "0" } {
                set dest $oprtr
puts "\n extLength: $extLength"
        #handoff callappl leg_incoming default "DESTINATION=$dest"
        if {($maxExtensionLen > 0) && ($extLength >= 0)} {
            leg setup $dest callInfo leg_incoming
        } else {
            set busyPrompt _bacd_invalidoption.au
            act_Select
    } elseif { ($status == "cd_001") || ($status == "cd_002") } {
        set dest $oprtr
    }   else {
        if { $status == "cd_006" } {
        puts "\nCall [infotag get con_all] got event $status collecting destination"
                set dest $oprtr
        } else {
                act_Select
proc act_CallSetupDone { } {
    global busyPrompt
    global legConnected
    if { $status == "ls_000" } {
        puts "\n Connection success"
        handoff appl leg_all default
        act_Cleanup
    } else {
        if { $legConnected == "false" } {
        puts "\n Call failed.  Play prompt and collect digit"
        if { ($status == "ls_007") } {
            set busyPrompt _dest_busy.au
        act_Select
proc act_Select { } {
    global destination
    global promptFlag2
    global destBusy
    global param1
    global fcnt
    global retrycnt
    global busyPrompt
    puts "\n proc act_Select"
    set promptFlag2 0
    set param1(dialPlanTerm) true
    if { $fcnt < $retrycnt } {
        media play leg_incoming $busyPrompt %s500 _reenter_dest.au
        incr fcnt
        fsm setstate GETDEST
    } else {
        act_DestBusy
proc act_DestBusy { } {
    puts "\n proc act_DestBusy"
    media play leg_incoming _disconnect.au
    fsm setstate CALLDISCONNECT
proc act_Cleanup { } {
    call close
requiredversion 2.0
init
init_ConfigVars
#   State Machine
  set fsm(any_state,ev_disconnected)   "act_Cleanup  same_state"
  set fsm(any_state,ev_disconnect_done)   "act_Cleanup  same_state"
  set fsm(CALL_INIT,ev_setup_indication) "act_Setup  GETDEST"
  set fsm(GETDEST,ev_collectdigits_done) "act_GotDest HANDOFF"
  #set fsm(HANDOFF,ev_returned)   "act_CallSetupDone  CONTINUE"
  set fsm(HANDOFF,ev_setup_done)   "act_CallSetupDone  CONTINUE"
  set fsm(CALLDISCONNECT,ev_media_done) "act_Cleanup  same_state"
  fsm define fsm CALL_INIT
# Script Approval Signature: C/775c
Also here is a detail debug..
*Feb 25 20:46:54.475: //-1/76B695000000/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=30110
   ----- ccCallInfo IE subfields -----
   cisco-ani=sip:30110@172.20.5.22
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=sip:5555@172.20.5.30:5060
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Feb 25 20:46:54.475: //-1/76B695000000/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x682705C8, Call Info(
   Calling Number=sip:30110@172.20.5.22,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=sip:5555@172.20.5.30:5060(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=5555, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=207
*Feb 25 20:46:54.475: //-1/76B695000000/CCAPI/ccCheckClipClir:
   In: Calling Number=sip:30110@172.20.5.22(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=sip:30110@172.20.5.22(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Feb 25 20:46:54.475: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 25 20:46:54.475: :cc_get_feature_vsa malloc success
*Feb 25 20:46:54.475:  cc_get_feature_vsa count is 1
*Feb 25 20:46:54.475: :FEATURE_VSA attributes are: feature_name:0,feature_time:1768577616,feature_id:97
*Feb 25 20:46:54.475: //207/76B695000000/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
*Feb 25 20:46:54.479: //207/76B695000000/CCAPI/cc_process_call_setup_ind:
   Event=0x68780750
*Feb 25 20:46:54.479: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 5555
*Feb 25 20:46:54.479: //-1//SERV:/AFW_Service_CCInterface: Received Event 26 for service test modulehandle NULL
*Feb 25 20:46:54.479: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = test
*Feb 25 20:46:54.479: //-1//AFW_:/AFW_Process_New: test
*Feb 25 20:46:54.483: //-1//SERV:/AFW_Service_GetExecEnv: Using Cached ExecEnv
*Feb 25 20:46:54.483: //-1//AFW_:EE6A392D60000:/AFW_ExecEnv_SetRoot: Execenv = 0x6A392D60
*Feb 25 20:46:54.483: //-1//AFW_:/AFW_M_TclModule_NewDup:
*Feb 25 20:46:54.483: //-1//AFW_:HN2D887F84:/AFW_M_TclModule_Free:  MOD[TclModule_6A39E3D8_0_763740224]    ( )
*Feb 25 20:46:54.483: //-1//AFW_:/AFW_M_FSM_Free:
*Feb 25 20:46:54.483: //-1//AFW_:/AFW_Process_Lock: pProcess(0x69681700)=1
*Feb 25 20:46:54.483: //-1//AFW_:LP:EE6A392D60000:HN2D967E88:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0
*Feb 25 20:46:54.483: //-1//AFW_:EE6A392D60000:/AFW_ExecEnv_RestoreDataBackup: Restore DataArea from Script
*Feb 25 20:46:54.487: //-1//AFW_:EE6A392D60000:/AFW_ExecEnv_RestoreDataBackup: Restore TokenTable from Script
*Feb 25 20:46:54.487: //-1//AFW_:EE6A392D60000:/AFW_ExecEnv_Initiate: Execenv = 0x6A392D60
*Feb 25 20:46:54.487: //-1//AFW_:EE6A392D60000:/AFW_ExecEnv_SetCallCorID:
*Feb 25 20:46:54.487:  CallCorID is v6
*Feb 25 20:46:54.487: //-1//AFW_:/AFW_Leg_New:
*Feb 25 20:46:54.487: //207/76B695000000/CCAPI/ccCallSetContext:
   Context=0x697CA32C
*Feb 25 20:46:54.487: //207//AFW_:/AFW_M_Leg_SetExecEnv:
*Feb 25 20:46:54.487: //-1//AFW_:EE6A392D60000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 1
*Feb 25 20:46:54.487: //-1//AFW_:LP:EE6A392D60000:LG207:/AFW_M_Object_SetExecEnv: ObjCount: 2, CmdPending 1
*Feb 25 20:46:54.487: //207//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
*Feb 25 20:46:54.487: //207//AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_207
*Feb 25 20:46:54.487: //-1//AFW_:EE6A392D60000:/AFW_ExecEnv_AssignCall: Execenv = 0x6A392D60, Leg = 207, Peer_Tag = 5555
*Feb 25 20:46:54.487: //207//AFW_:/AFW_ExecEnv_SetCallCorID:
*Feb 25 20:46:54.487: //207/76B695000000/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 207 with tag 5555 to app "_ManagedAppProcess_test"
*Feb 25 20:46:54.487: //-1//SERV:/AFW_Service_Process_Space:
*Feb 25 20:46:54.487: Process Started
*Feb 25 20:46:54.487: //-1//AFW_:/AFW_Process_Register: ccAppInitialize(name: _ManagedAppProcess_test)
*Feb 25 20:46:54.491: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event
*Feb 25 20:46:54.491: //207//AFW_:/AFW_Process_GetCcqEvent: Received
*Feb 25 20:46:54.491: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_SETUP_IND(34)] {
*Feb 25 20:46:54.491: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x6A392D60][test]
*Feb 25 20:46:54.491: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[207][LEG_INIT(0)][Cause(0)]
*Feb 25 20:46:54.491: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
*Feb 25 20:46:54.491: //207//SSIN:/AFW_SS_MapEvent:
*Feb 25 20:46:54.491: //-1//SSIN:/AFW_SS_SIP_MapEvent:
*Feb 25 20:46:54.491: //207/76B695000000/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 6C type 0
*Feb 25 20:46:54.495: //207/76B695000000/AFW_:/incrementIncomingDialPeerCallStats: Incrementing call-stat to [1] for dial-peer [5555]
*Feb 25 20:46:54.495: //207/76B695000000/AFW_:/AFW_Object_WalkListeners:
*Feb 25 20:46:54.495: //207/76B695000000/AFW_:/AFW_M_Object_ShowListeners: START
*Feb 25 20:46:54.495: //-1//AFW_:/AFW_M_Object_ShowListeners:
*Feb 25 20:46:54.495: //207//AFW_:/AFW_M_Module_GetHandle: Module handle: TclModule_682ADEDC_0_764837512MOD[TclModule_682ADEDC_0_764837512]  (
*Feb 25 20:46:54.495: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[207][LEG_INCINIT(1)][Cause(0)]
*Feb 25 20:46:54.495: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
*Feb 25 20:46:54.495: //207/76B695000000/AFW_:/AFW_M_Object_ShowListeners: END
*Feb 25 20:46:54.495: //207/76B695000000/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
*Feb 25 20:46:54.495: //207//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_682ADEDC_0_764837512 ---> TclModule_682ADEDC_0_764837512
*Feb 25 20:46:54.495: //207//AFW_:/AFW_M_TclModule_Action:
*Feb 25 20:46:54.495: //207//AFW_:/AFW_TclModule_DefaultEvHandling:
*Feb 25 20:46:54.495: //207/76B695000000/AFW_:/AFW_Leg_CheckIncomingCallBlock:
*Feb 25 20:46:54.495: //207/76B695000000/AFW_:/AFW_Leg_SettlementValidateCall: target=, tokenp=0x0
*Feb 25 20:46:54.495: //207/76B695000000/AFW_:/AFW_Leg_IncomingTranslate:
*Feb 25 20:46:54.495: //-1//AFW_:/AFW_Leg_IncomingTranslate: Tag(5555) calling[30110] redirect[] called[5555]
*Feb 25 20:46:54.495: //207//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(CALL_INIT[1],ev_setup_indication[34])---[act_Setup]------
*Feb 25 20:46:54.495: //207//TCL :/tcl_PutsObjCmd: proc act_Setup
*Feb 25 20:46:54.499: //207//TCL :/tcl_InfotagObjCmd:  infotag get leg_ani
*Feb 25 20:46:54.499: //207//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani
*Feb 25 20:46:54.499: //207//AFW_:/vtr_lg_ani: argc 2 argindex 2
*Feb 25 20:46:54.499: //207//TCL :/tcl_PutsObjCmd:
*Feb 25 20:46:54.499: //207//TCL :/tcl_InfotagObjCmd:  infotag get leg_dnis
*Feb 25 20:46:54.499: //207//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
*Feb 25 20:46:54.499: //207//AFW_:/vtr_lg_dnis: argc 2 argindex 2
*Feb 25 20:46:54.499: //207//TCL :/tcl_InfotagObjCmd:  infotag set med_language 1
*Feb 25 20:46:54.499: //207//TCL :/tcl_InfotagSetObjCmd: infotag set med_language 1
*Feb 25 20:46:54.499: //207//AFW_:/vtw_ms_language: argc 3 argindex 2
*Feb 25 20:46:54.499: //207//TCL :/tcl_LegObjCmd:  leg setupack leg_incoming
*Feb 25 20:46:54.499: //207//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
*Feb 25 20:46:54.499: //207//AFW_:/vtd_lg_incoming: argc 2
*Feb 25 20:46:54.499: //207//AFW_:/vtd_lg_incoming: Legs [207 ]
*Feb 25 20:46:54.499: //207//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
*Feb 25 20:46:54.499: //207/76B695000000/CCAPI/ccCallSetupAck:
   Call Id=207
*Feb 25 20:46:54.503: //207/76B695000000/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
*Feb 25 20:46:54.503: //207//TCL :/tcl_LegObjCmd:  leg setup sip:5555@172.20.5.30:5060 callInfo leg_incoming
*Feb 25 20:46:54.503: //207//CSPK:/tcl_LegSetupObjCmd: leg setup sip:5555@172.20.5.30:5060 callInfo leg_incoming
*Feb 25 20:46:54.503: //207//AFW_:/vtd_lg_incoming: argc 4
*Feb 25 20:46:54.503: //207//AFW_:/vtd_lg_incoming: Legs [207 ]
*Feb 25 20:46:54.503: //207//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
*Feb 25 20:46:54.503: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: copied
*Feb 25 20:46:54.503: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
   mempool not found from usrContainer(69491D2C)
*Feb 25 20:46:54.503: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
   Mempool(6A33B728) created in usrContainer(69491D2C)
*Feb 25 20:46:54.503: //-1//AFW_:/AFW_Util_GetUsrContainerData: Container is present, No data
*Feb 25 20:46:54.503: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: Successful in setting 'CC_TAG_SETUP_REQ_DATA' in usrContainer(69491D2C)
*Feb 25 20:46:54.503: ccDumpTdRequestDataGen:
*Feb 25 20:46:54.503:   called_urip=NULL
*Feb 25 20:46:54.503:   calling_urip=sip:30110@172.20.5.22
*Feb 25 20:46:54.503: url_dump_header_line_avpair:
*Feb 25 20:46:54.503:   num_bodies = 0
*Feb 25 20:46:54.503: //-1//AFW_:/AFW_Util_CopyLegServiceCodeToCallInfoContainer: Service Code not available on Leg
*Feb 25 20:46:54.503: //-1//AFW_:/AFW_Util_CopyLegRouteCodeToCallInfoContainer: Route Code not available on Leg
*Feb 25 20:46:54.503: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not  found for tag(56)
*Feb 25 20:46:54.507: //-1//CSPK:/tclSetControlParams: alertTime(30) = 30
*Feb 25 20:46:54.507: //207//CSPK:/C_CallSetup_Start: ControlInfo = 0x6A3AD338, callInfo = 0x6A3C1658, destination[0]=sip:5555@172.20.5.30:5060
*Feb 25 20:46:54.507: //207//CSPK:/C_CallSetup_Start: configured mode=rotary (1)
*Feb 25 20:46:54.507: //207//CSPK:/C_CallSetup_Start: configured reroutemode=rotary (1)
*Feb 25 20:46:54.507: //-1//Call:/AFW_CallSetup_New:
*Feb 25 20:46:54.507: //-1//AFW_:/AFW_FSM_New:
*Feb 25 20:46:54.507: //-1//AFW_:LP:EE6A392D60000:HN2D967EA0:/AFW_M_Object_SetExecEnv: ObjCount: 3, CmdPending 1
*Feb 25 20:46:54.507: //207//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 2
*Feb 25 20:46:54.507: //207//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
*Feb 25 20:46:54.507: //207//AFW_:/AFW_M_Module_GetHandle: Module handle: CallSetup_698003EC_0_764837536
*Feb 25 20:46:54.507: //207//Call:/AFW_CallSetup_AddDest:  sip:5555@172.20.5.30:5060 index 0
*Feb 25 20:46:54.507: //207//Call:/AFW_CallSetup_SetIntWrkLeg:
*Feb 25 20:46:54.507: //207/76B695000000/AFW_:/AFW_Leg_SignalPeerGet: Leg [207]
*Feb 25 20:46:54.507: //-1//AFW_:/C_PackageSession_GetSigPeer:
*Feb 25 20:46:54.507: //207/76B695000000/AFW_:/C_PackageSession_GetSigPeer: No Interworking module on Leg, no signal peer
*Feb 25 20:46:54.511: //207//Call:/AFW_M_CallSetup_Initiate:
*Feb 25 20:46:54.511: //207/76B695000000/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
*Feb 25 20:46:54.511: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
*Feb 25 20:46:54.511: //207//Call:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
*Feb 25 20:46:54.511: //207//Call:/CallSetupInitiate:
*Feb 25 20:46:54.511: //207//Call:/CS_Placecall:
*Feb 25 20:46:54.511: //207//Call:/setupHuntGroupInfo: hunt group destination has to be E.164 number
*Feb 25 20:46:54.511: //-1//Dest:/AFW_Destination_New:
*Feb 25 20:46:54.511: //-1//AFW_:/AFW_FSM_New:
*Feb 25 20:46:54.511: //-1//AFW_:LP:EE6A392D60000:HN2D967EA4:/AFW_M_Object_SetExecEnv: ObjCount: 4, CmdPending 2
*Feb 25 20:46:54.511: //207//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 3
*Feb 25 20:46:54.511: //207//AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
*Feb 25 20:46:54.511: //207//AFW_:/AFW_M_Module_GetHandle: Module handle: Destination_698326C4_0_764837540
*Feb 25 20:46:54.511: //207//Dest:/AFW_Destination_AddDest:
*Feb 25 20:46:54.511: //-1//Dest:/AFW_Destination_AddDest: adding destination "sip:5555@172.20.5.30:5060"
*Feb 25 20:46:54.515: //207//Dest:/AFW_Destination_SetIntWrkLeg: LEG[207    ][LEG_INCACKED(2)][Cause(0)]
*Feb 25 20:46:54.515: //207//Dest:/TermInterworking: current state IW_STATE_INIT, Keep IntWrkLeg
*Feb 25 20:46:54.515: //207//Dest:/DestSetIntWrkLeg:
*Feb 25 20:46:54.515: //207/76B695000000/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
*Feb 25 20:46:54.515: //207//Dest:/AFW_M_Destination_Initiate:
*Feb 25 20:46:54.515: //-1//AFW_:/AFW_Util_SaveRawMsg:
*Feb 25 20:46:54.515: //207//Dest:/AFW_M_Destination_Initiate: Outgoing guid : 76B69500.00010000.00000045.160514AC
*Feb 25 20:46:54.515:  Incoming_guid : 00000000.00000000.00000000.00000000
*Feb 25 20:46:54.515: //207//Dest:/AFW_M_Destination_Initiate: Outgoing gcid : BCF7DB89.DB3711E5.81958EDD.70D74969
*Feb 25 20:46:54.515:  Incoming_gcid : 00000000.00000000.00000000.00000000
*Feb 25 20:46:54.515: //207/76B695000000/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
*Feb 25 20:46:54.515: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
*Feb 25 20:46:54.515: //207//Dest:/DestUpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)] Preempt Hunt Not Set
*Feb 25 20:46:54.515: //207//Dest:/DestSetupInitiate:
*Feb 25 20:46:54.515: //207/76B695000000/SSIN:/AFW_SS_SIP_CheckConsultSetup:
*Feb 25 20:46:54.515: //207//Dest:/DestAddRerouteSetupInfo:
*Feb 25 20:46:54.515: //207//Dest:/DestAddTransferSetupInfo:
*Feb 25 20:46:54.515: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: copied sip:5555@172.20.5.30:5060
*Feb 25 20:46:54.515: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: Successful in setting 'CC_TAG_SETUP_REQ_DATA' in usrContainer(69491D2C)
*Feb 25 20:46:54.515: ccDumpTdRequestDataGen:
*Feb 25 20:46:54.515:   called_urip=sip:5555@172.20.5.30:5060
*Feb 25 20:46:54.515:   calling_urip=sip:30110@172.20.5.22
*Feb 25 20:46:54.515: url_dump_header_line_avpair:
*Feb 25 20:46:54.515:   num_bodies = 0
*Feb 25 20:46:54.515: //207//Dest:/DestMatchDialPeer:
*Feb 25 20:46:54.519: //207//Dest:/DestMatchDialPeer: src carrier id:, tgt carrier id:
*Feb 25 20:46:54.519: //207//Dest:/DestSetupInitiate:  Did not match any peers
*Feb 25 20:46:54.519: //207//Dest:/DestResetCallInfo:
*Feb 25 20:46:54.519: //207//Dest:/DestComplete: peer #:0 IW State IW_STATE_INIT, OB State OB_STATE_INIT
*Feb 25 20:46:54.519: //-1//Dest:/DestStatusFromDiscCause: mapped "unassigned number (1)"(1) to DEST_INVALID_NUMBER(4)
*Feb 25 20:46:54.519: //-1//AFW_:/AFW_Event_New: Event ID: ev_destination_done
*Feb 25 20:46:54.519: //207//AFW_:/AFW_Module_ReturnArgEv:
*Feb 25 20:46:54.519: //207//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[207    ][LEG_INCACKED(2)][Cause(0)]}
*Feb 25 20:46:54.519: //207/76B695000000/AFW_:/AFW_Object_RemoveListener:
*Feb 25 20:46:54.519: //207//AFW_:/AFW_Module_UnListen:  NumObjects: 0
*Feb 25 20:46:54.519: //207//Dest:/DestReturn: Destination Returning(ds_004 Status DEST_INVALID_NUMBER)
*Feb 25 20:46:54.519: //207//Call:/CS_Placecall: Call placed to sip:5555@172.20.5.30:5060 index 0
*Feb 25 20:46:54.519: //207//TCL :/tcl_FSMObjCmd:  fsm setstate HANDOFF
*Feb 25 20:46:54.519: //207//TCL :/tcl_FSMSetStateObjCmd: setstate setstate HANDOFF
*Feb 25 20:46:54.519: //207//AFW_:/AFW_FSM_Drive: ACTION END: -------------(HANDOFF[4])---------------
*Feb 25 20:46:54.519: //207//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_682ADEDC_0_764837512 ---> TclModule_682ADEDC_0_764837512
*Feb 25 20:46:54.523: //207/76B695000000/AFW_:/AFW_M_Event_Free:
*Feb 25 20:46:54.523: //207//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
*Feb 25 20:46:54.523: //207//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
*Feb 25 20:46:54.523: //207//AFW_:/AFW_Process_GetPriorityQEvent: Received
*Feb 25 20:46:54.523: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_DESTINATION_DONE(221)] {
*Feb 25 20:46:54.523: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x6A392D60][test]
*Feb 25 20:46:54.523: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[Destination_698326C4_0_764837540]  (
*Feb 25 20:46:54.523: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
*Feb 25 20:46:54.523: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
*Feb 25 20:46:54.523: //207//Dest:/AFW_M_Destination_EventPreProcess:
*Feb 25 20:46:54.523: //207//AFW_:/AFW_Object_WalkListeners:
*Feb 25 20:46:54.523: //207//AFW_:/AFW_M_Object_ShowListeners: START
*Feb 25 20:46:54.523: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[CallSetup_698003EC_0_764837536]  (
*Feb 25 20:46:54.523: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Destination_698326C4_0_764837540]  (
*Feb 25 20:46:54.523: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 25 20:46:54.523: //207//AFW_:/AFW_M_Object_ShowListeners: END
*Feb 25 20:46:54.523: //207//AFW_:/AFW_Object_WalkListeners: Entering Module : CallSetup
*Feb 25 20:46:54.523: //207/76B695000000/AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
*Feb 25 20:46:54.523: //207//AFW_:/AFW_Object_RemoveListener:
*Feb 25 20:46:54.523: //207//AFW_:/AFW_Module_UnListen:  NumObjects: 1
*Feb 25 20:46:54.527: //207//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_698003EC_0_764837536
*Feb 25 20:46:54.527: //207//Call:/AFW_M_CallSetup_Action:
*Feb 25 20:46:54.527: //207//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_destination_done[221])---[C_Action]------
*Feb 25 20:46:54.527: //207//Call:/CS_Placecall_DestDone:
*Feb 25 20:46:54.527: //207//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_DONE[13])---------------
*Feb 25 20:46:54.527: //-1//AFW_:/AFW_Event_New: Event ID: ev_setup_done
*Feb 25 20:46:54.527: //207//AFW_:/AFW_Module_ReturnArgEv:
*Feb 25 20:46:54.527: //207//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[207    ][LEG_INCACKED(2)][Cause(0)]}
*Feb 25 20:46:54.527: //207/76B695000000/AFW_:/AFW_Object_RemoveListener:
*Feb 25 20:46:54.527: //207//AFW_:/AFW_Module_UnListen:  NumObjects: 0
*Feb 25 20:46:54.527: //207//Call:/CS_Complete: CallSetup Returning(ls_004 Status CS_INVALID_NUMBER)
*Feb 25 20:46:54.527: //207//AFW_:/AFW_ExecEnv_SetModuleScope: CallSetup_698003EC_0_764837536 ---> NULL
*Feb 25 20:46:54.527: //207//AFW_:/AFW_Object_WalkListeners:
*Feb 25 20:46:54.527: //207//AFW_:/AFW_M_Object_ShowListeners: START
*Feb 25 20:46:54.527: //207//AFW_:/AFW_M_Object_ShowListeners: END
*Feb 25 20:46:54.527: //207//AFW_:/AFW_M_Event_Free:
*Feb 25 20:46:54.527: //207//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: Destination_698326C4_0_764837540
*Feb 25 20:46:54.527: //207//AFW_:/AFW_Object_RemoveAllListener:
*Feb 25 20:46:54.527: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 3, CmdPending 3
*Feb 25 20:46:54.527: //207//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 2
*Feb 25 20:46:54.527: //-1//AFW_:HN2D967EA4:/AFW_M_Event_Free: ExecEnv objCount: 3
*Feb 25 20:46:54.527: //-1//Dest:HN2D967EA4:/AFW_M_Destination_Free:
*Feb 25 20:46:54.527: //-1//Dest:HN2D967EA4:/DestEmptyPreemptHoldQ:
*Feb 25 20:46:54.527: //-1//AFW_:/AFW_M_FSM_Free:
*Feb 25 20:46:54.531: //207//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 2
*Feb 25 20:46:54.531: //207//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
*Feb 25 20:46:54.531: //207//AFW_:/AFW_Process_GetPriorityQEvent: Received
*Feb 25 20:46:54.531: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_CALLSETUP_DONE(219)] {
*Feb 25 20:46:54.531: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x6A392D60][test]
*Feb 25 20:46:54.531: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[CallSetup_698003EC_0_764837536]  (
*Feb 25 20:46:54.531: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
*Feb 25 20:46:54.531: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
*Feb 25 20:46:54.531: //207//Call:/AFW_M_CallSetup_EventPreProcess:
*Feb 25 20:46:54.531: //207//AFW_:/AFW_Object_WalkListeners:
*Feb 25 20:46:54.531: //207//AFW_:/AFW_M_Object_ShowListeners: START
*Feb 25 20:46:54.531: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_682ADEDC_0_764837512]  (
*Feb 25 20:46:54.531: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[207][LEG_INCACKED(2)][Cause(0)]
*Feb 25 20:46:54.531: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_698003EC_0_764837536]  (
*Feb 25 20:46:54.531: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
*Feb 25 20:46:54.531: //207//AFW_:/AFW_M_Object_ShowListeners: END
*Feb 25 20:46:54.531: //207//AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
*Feb 25 20:46:54.531: //207/76B695000000/AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
*Feb 25 20:46:54.535: //207//AFW_:/AFW_Object_RemoveListener:
*Feb 25 20:46:54.535: //207//AFW_:/AFW_Module_UnListen:  NumObjects: 1
*Feb 25 20:46:54.535: //207//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_682ADEDC_0_764837512
*Feb 25 20:46:54.535: //207//AFW_:/AFW_M_TclModule_Action:
*Feb 25 20:46:54.535: //207//AFW_:/AFW_TclModule_DefaultEvHandling:
*Feb 25 20:46:54.535: //207//AFW_:/AFW_TclModule_UpdateSessionMask: Update intwrk-mask for leg [207]'s session
*Feb 25 20:46:54.535: //207//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(HANDOFF[4],ev_setup_done[219])---[act_CallSetupDone]------
*Feb 25 20:46:54.535: //207//TCL :/tcl_InfotagObjCmd:  infotag get evt_status
*Feb 25 20:46:54.535: //207//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status
*Feb 25 20:46:54.535: //207//AFW_:/vtr_ev_status: argc 2 argindex 2
*Feb 25 20:46:54.535: //207//TCL :/tcl_PutsObjCmd:
proc act_Select
*Feb 25 20:46:54.535: //207//TCL :/tcl_LegObjCmd:  leg collectdigits leg_incoming param1
*Feb 25 20:46:54.535: //207//Digi:/tcl_LegDigitCollectObjCmd: collectdigits leg_incoming param1
*Feb 25 20:46:54.535: //207//AFW_:/vtd_lg_incoming: argc 3
*Feb 25 20:46:54.535: //207//AFW_:/vtd_lg_incoming: Legs [207 ]
*Feb 25 20:46:54.539: //207//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
*Feb 25 20:46:54.539: //207//Digi:/C_DigitCollect_Start: Leg=207, Dialplan=True, Diaplanterm=True, DigitReport=False, DigitConsume=False IgnoreInitialKey=False, IgnoreDTMFacceptINFO=False, Abortkey=*, Terminationkey=#, Numpatterns=0, Maxdigits=0, Mindigits=0, Interruptprompt=True, InterTimeout=-1000, Initialtimeout=-1000, Mask=0 Hotword=0
*Feb 25 20:46:54.539: //-1//Digi:/AFW_DigitCollect_New:
*Feb 25 20:46:54.539: //-1//Digi:HN2D967EC0:/AFW_DigitCollect_New: DialPlan=TRUE AbortKey=* TermKey=# NumPatts=0
              Enable=FALSE Consume=FALSE InterruptPrompt=TRUE minDigits=0 maxDigits=0 DialPlanTerm=TRUE hotword=0
*Feb 25 20:46:54.539: //-1//AFW_:LP:EE6A392D60000:HN2D967EC0:/AFW_M_Object_SetExecEnv: ObjCount: 4, CmdPending 2
*Feb 25 20:46:54.539: //207//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
*Feb 25 20:46:54.539: //207//AFW_:/AFW_M_Module_GetHandle: Module handle: DigitCollect_6A37B624_0_764837568
*Feb 25 20:46:54.539: //207/76B695000000/AFW_:/AFW_Object_AddListener: adding Module DigitCollect as listener
*Feb 25 20:46:54.539: //207/76B695000000/Digi:/DigitCollectStart_UpdateStats:
*Feb 25 20:46:54.539: //207//Digi:/DigitCollect_MLPPTuning:
*Feb 25 20:46:54.539: //207/76B695000000/AFW_:/AFW_Leg_PrecedenceDcValid:
*Feb 25 20:46:54.539: //207//Digi:/DigitCollect_MLPPTuning: Precednece Digit Collect not enabled
*Feb 25 20:46:54.539: //207/76B695000000/AFW_:/AFW_Leg_TypeAheadGet: no chars in buffer.
*Feb 25 20:46:54.539: //207/76B695000000/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
*Feb 25 20:46:54.539: //207/76B695000000/AFW_:/AFW_Leg_DigitReportEnable: Current: 0x0 Input: 0x2
*Feb 25 20:46:54.539: //207/76B695000000/CCAPI/ccCallReportDigits:
   (callID=0xCF, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=207
*Feb 25 20:46:54.543: //207//TCL :/tcl_PutsObjCmd:
proc act_DestBusy
*Feb 25 20:46:54.543: //207//PACK:/tcl_MediaObjCmd:  media play leg_incoming _disconnect.au
*Feb 25 20:46:54.543: //207//PACK:/tcl_MediaPlayObjCmd:  play leg_incoming _disconnect.au
*Feb 25 20:46:54.543: //207//AFW_:/vtd_lg_incoming: argc 3
*Feb 25 20:46:54.543: //207//AFW_:/vtd_lg_incoming: Legs [207 ]
*Feb 25 20:46:54.543: //207//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
*Feb 25 20:46:54.543: //-1//DPM :DP86:/pc_mc_addToDynamicS: (1) _disconnect.au
*Feb 25 20:46:54.543: //-1//DPM :DP86:/pc_mc_addToDynamicS: Doing : _disconnect.au
*Feb 25 20:46:54.543: //-1//DPM :/mcTokenizerGetNext: savedcharptr=_ endptrptr=_disconnect.au
*Feb 25 20:46:54.543: //-1//DPM :DP86:/pc_mc_addToDynamicS: Token : _disconnect.au status 1
*Feb 25 20:46:54.543: //-1//DPM :DP86:/pc_mc_addToDynamicS: call dp_mcDQfromFileDynamic() to Handle relative file name
*Feb 25 20:46:54.543: //-1//DPM :DP86:/dp_mcDQfromFileDynamic:  pLanguage=en FileName=_disconnect.au
*Feb 25 20:46:54.543: //-1//DPM :DP86:/dp_mcDQfromURL:  file=flash:en_disconnect.au
*Feb 25 20:46:54.543: //-1//MCM :/mc_createFromFileUrl: Getting a media content: name=en_disconnect.au
    url=flash:en_disconnect.au
    load fast, fetchtimeout=-1
*Feb 25 20:46:54.543: //-1//MCM :MC14:/mc_getFromUrlName: en_disconnect.au on ram
*Feb 25 20:46:54.543: //-1//MCM :/mc_createFromFileUrl: Found a good mc (0x6A3AF9A8), RefCount(1)
*Feb 25 20:46:54.543: //-1//DPM :DP86:/dp_mcDQfromURL: mc_createFromFileUrl OK
*Feb 25 20:46:54.543: //-1//DPM :/mcTokenizerGetNext: savedcharptr= endptrptr=
*Feb 25 20:46:54.543: //207//PACK:/Media_Play_Start:
*Feb 25 20:46:54.547: //-1//PACK:/Media_Play_Start: pLeg->stream is null,  call msw_create()
*Feb 25 20:46:54.547: //207//MSW :/msw_create: cbf=0x62A841C0
*Feb 25 20:46:54.547: //-1//MSM :MS111:/ms_create: Iniz ply_timer
*Feb 25 20:46:54.547: //207//MSW :/msw_synth_open: mediaStream 0x6A333418 created
*Feb 25 20:46:54.547: //207//MSW :/msw_synth_open: rtspStream 0x6848A1EC created,
            status=RTSP_STATUS_SUCCESS, session_id=0x6F (111)
*Feb 25 20:46:54.547: //207//MSW :/msw_synth_open: AIS : Creating TTS AIS Backend record
*Feb 25 20:46:54.547: //207//MRCP:/mrcp_create_session:
   url=rtsp://tts-en-us/synthesizer, type=SYNTHESIZER, streamcontext=0x68489B54, sess_id=-1
   New SCB creation
*Feb 25 20:46:54.547: //207//MRCP:/mrcp_add_synthesizer_fsm:
   adding synthesizer fsm
*Feb 25 20:46:54.547: //207//MRCP:/mrcp_add_connection_fsm:
   adding connection fsm
   adding connection (fsm) 6984C360
*Feb 25 20:46:54.547: //207//MRCP:/mrcp_add_rtpsetup_fsm:
   adding rtpsetup fsm
*Feb 25 20:46:54.547: //207//MRCP:/mrcp_create_svr_session_url:
*Feb 25 20:46:54.547: //-1//MRCP:/hash_get:
   Table=mrcp_host_stat_table, Key=12
*Feb 25 20:46:54.547: //-1//MSM :MS112:/ms_create: Iniz ply_timer
*Feb 25 20:46:54.547: //207//MSW :/msw_recrd_open:
*Feb 25 20:46:54.547: :msw_recrd_open mediaStream 0x69773964 created
*Feb 25 20:46:54.547: //207//MSW :/msw_recrd_open: rtspStream 0x6848A1F4 created,
            status=RTSP_STATUS_SUCCESS, session_id=0x70 (112)
*Feb 25 20:46:54.547: //207//MSW :/msw_recog_open: AIS : Creating ASR AIS Backend record
   url=rtsp://asr-en-us/recognizer, type=RECOGNIZER, streamcontext=0x68489C10, sess_id=57
   Already an  SCB is created for this call
*Feb 25 20:46:54.547: //207//MRCP:/mrcp_add_recognizer_fsm:
   adding recognizer fsm
   adding connection (fsm) 6A35AF84
*Feb 25 20:46:54.551: //207//MRCP:/mrcp_add_rtpsetup_fsm:
   adding rtpsetup fsm
*Feb 25 20:46:54.551: //207//MRCP:/mrcp_create_svr_session_url:
*Feb 25 20:46:54.551: //-1//MRCP:/hash_get:
   Table=mrcp_host_stat_table, Key=41
*Feb 25 20:46:54.551: //-1//PACK:/Media_Play_Start: msw_create() succeed to create stream [56]
*Feb 25 20:46:54.551: //-1//MSW :/msw_associate_call:
*Feb 25 20:46:54.551: msw_associate_call: callID=0xCF(207),
                     genericStream=0x68489B50
*Feb 25 20:46:54.551: //207//MRCP:/mrcp_associate_call:
   sess_id=57, type=SYNTHESIZER
   sess_id=57, type=RECOGNIZER
*Feb 25 20:46:54.551: //207//MSW :/msw_synth_get_stream_state: genericStream 0x68489B50 is in state MSW_S_IDLE
*Feb 25 20:46:54.551: //-1//MSW :/msw_synth_start:
*Feb 25 20:46:54.551: msw_synth_start: Enter...
*Feb 25 20:46:54.551: //207//MSW :/msw_synth_start: current_stream_id=1, content 0x0, dynamicS 0x6976D738, current_state=MSW_S_IDLE
*Feb 25 20:46:54.551: //-1//MSW :/msw_synth_start: msw_synth_start: p_mcDynamicS, We've been given a list of URLs to play.
*Feb 25 20:46:54.551: //-1//MSW :/msw_synth_start:      p_mcDynamicQ is NOT empty
*Feb 25 20:46:54.551: //207//MSW :/msu_synth_partial_play: Media Stream URL
*Feb 25 20:46:54.551: //207/76B695000000/CCAPI/ccAssociateStream:
   Coder=5, DTMF Relay=1, Vad=0,
   Record Function=0x0, Event Queue=0x6876B948, Stream Context=6A333418,
   Record Context=0x0, Stream Call Id=208, Call Id=207
   Call Entry(Stream Status=2, Digit Enable=FALSE)
*Feb 25 20:46:54.551: //207//TCL :/tcl_FSMObjCmd:  fsm setstate CALLDISCONNECT
*Feb 25 20:46:54.551: //207//TCL :/tcl_FSMSetStateObjCmd: setstate setstate CALLDISCONNECT
*Feb 25 20:46:54.551: //207//AFW_:/AFW_FSM_Drive: ACTION END: -------------(CALLDISCONNECT[2])
From the log you have, this may relate to the environment you have. Can you please briefly describe what you are trying to achieve ? Maybe we can find another script fit your application better.
From call manager dial in to GW script ( DN 5555 dia peer trough sip trunk) scripts answer ask for destination number to connect call trough PSTN or another extension on CM and connect them .
-- CM Ext 30110-- sip trunk DN 555 ---> GW--Tranfer to Destination number -- PSTN or another extension on CM
Thanks in advance
Here is the issue:
You are totally right -- i mad call trough FXS or sccp .. and it works since it  is no sip and for SIP also made transformation for dest 5555@xxxxxx to 5555 and it works
thanks
what tool do you suggest for recording new audio (prompts) to customize my self
Not following recording tool lately but any tool can record .wav or .au file should be fine. I would use G.711 format to be safe.
How do i modify length destination ??? always keep 5    set dest [infotag get evt_dcdigits] from this event here
*Feb 26 20:23:16.691: //65//TCL :/tcl_PutsObjCmd:
DESTLEN: 5
          call close
    } else {
so you need to add "param max-extension-length  ?" to the max digit length you want in the following
Default is 5
  param aa-pilot 5555
  param operator 9998
I believe thats the extension witch im calling and the one for connect destination is different
global maxExtensionLen  -- > this one i could modified to 13 with out problem param max-extension-length
global destExtLen  -- this one is what i need to increase
MAXEXTENSION: 13
*Feb 26 22:10:41.615:
*Feb 26 22:10:41.615: //90//TCL :/tcl_InfotagObjCmd:  infotag get evt_dcdigits
*Feb 26 22:10:41.615: //90//TCL :/tcl_InfotagGetObjCmd: infotag get evt_dcdigits
*Feb 26 22:10:41.615: //90//AFW_:/vtr_ev_dcdigits: argc 2
*Feb 26 22:10:41.615: //90//AFW_:/vtr_ev_dcdigits: DCDIGITS [33300]
*Feb 26 22:10:41.615: //90//TCL :/tcl_PutsObjCmd:
DESTLEN: 5
extLength: 8
DIGITS: 33300
so i enter when ask for destination 330038670 and cut it to the first 5 digits
    global dest
    global destExtLen
    global callInfo
    global oprtr
    global busyPrompt
    global pin
                set dest $oprtr
puts "\n DIGITS: $dest"
you may need to reload the service after adding new param
did that too but no work,
from my interpretation of code i don see relation between  maxExtensionLen and destExtLen
as you mention maxExtensionLen is defined on parameter begin of code  and i think is used for extension i am using to dial in to service but destExtLen gets digits from evt_dcdigits witch are digit that i enter when audio prompt is played but only takes first 5 .. any ideas ?
c act_GotDest { } {
    global dest
    global destExtLen
    global callInfo
    global oprtr
    global busyPrompt
    global pin
Can you please attach debug ?
Ok,
dialPlan is set to true so check you IOS dial-plan
other way to do is like this:
    set param1(maxDigits) $maxExtensionLen
    set param1(initialDigitTimeout) 5
