Configure boot order using Cisco UCS Power Tool
How can the following be configured using the Cisco UCS Power Tool for IMC (Cisco C240)?
Server# scope bios
Server /bios # set boot-order hdd,cdrom,fdd,pxe,efi
Server /bios *# commit
Server /bios # show detail
I can find cmdlets for configuring Advanced boot order, but I want to configure Basic boot order.
rrawal
If nothing id added, use the below Add commands-
Get-ImcBootDefinition | Add-ImcLsbootStorage -Order 1
Get-ImcBootDefinition | Add-ImcLsbootVirtualMedia -Access "read-only" -Order 2
Get-ImcBootDefinition | Add-ImcLsbootVirtualMedia -Access "read-write" -Order 3
Get-ImcBootDefinition | Add-ImcLsbootLan -Order 4
Get-ImcBootDefinition | Add-ImcLsbootEfi -Order 5
If some boot orders are already added then use the below commands to set the respective orders -
Get-ImcLsbootStorage -Type "storage" | Set-ImcLsbootStorage -Order "1" -Force
Get-ImcLsbootVirtualMedia  -Access "read-only" | Set-ImcLsbootVirtualMedia -Order "2" -Force
Get-ImcLsbootVirtualMedia -Access "read-write" | Set-ImcLsbootVirtualMedia -Order "3" -Force
Get-ImcLsbootLan -Type "lan" | Set-ImcLsbootLan -Order "4" -Force
Get-ImcLsbootEfi -Type efi | Set-ImcLsbootEfi -Order 5 -Force
rrawal
Thanks Rishi!
Does the following command also work for booting from M.2 disks in UEFI mode?
This particular command will set the efi at 5th preference of boot order. If higher preference is required then change the order accordingly while setting order.
Great, thanks a lot!
Cisco UCS X-Series Energy Efficiency Offer
