User switch between guest and <username>(for efg bob) for the same session
prabisht
Hi Team ,
I am facing issue with EFM session api. If I hit the session api.
For the same session I am geeting two different user name (some times "bob", some time "guest")
as shown in snapshot. Is there any known issue on server side or any other pointer how can I debug the problemsession_2.pngsession_1.png
Steve Zhang
If you don't login, the user will be "guest" for the session.
And if you login, the user will be the specific username you login for the session.
@Steve Zhang , Thanks your reply , But I am facing this issue while I am logged in as bob.not like I was logged out.
Elias Sghaier
we have not seen this issue in the past but at first glance this seems to be an issue with DGLux. What EFM Version is in use and is this issue reproducible? E.g. Happening when two different browsers/tabs are in use etc.?
Meanwhile I'll try to reproduce this issue in our lab.
