04-08-2018 08:12 AM - edited 03-17-2019 07:27 PM
I think to buy a spark device (SX or MX).
This device will be registered to Spark but it has to still be linked to an H323 visio gateway (in the cloud) because I need to cantact and be contacted by partners who don't have spark.
Is it possible to be dual registered (spark and H323) ?
Thanks for your help
04-08-2018 08:33 AM
What you need to do is attach the WebEx service to your spark device subscription. WebEx will allow you to handle SIP/H323/Skype interoperability in the cloud. If you don't have that bridging service, then spark service natively only supports SIP calling and hence the need for WebEx
04-11-2018 02:44 AM
Thanks a lot for your answer.
Does it means that, when you are connected to Spark, the embedded H323 capacity of MX/SX is disabled?
When I want to contact my partners, I just want to make a H323 point to point call (without using the cloud Spark or Webex, just by using the registered H323 gatekeeper).
In fact, It’s really about two usecase completly different.
04-11-2018 05:59 AM
Yes spark reg doesn’t allow any built in multi site, that’s only there if you do CCM registration. So a P2P call to H323 via spark cloud would entail a bridging service
CCM on the other hand or expressway C reg can handle what you are trying to do
Srini
