ptim.exe WebEx Productivity Tools CPU utilization (2)
peter.hunt11
Ptim.exe constantly uses ~3-6% CPU on my system. I'm running the latest version (31.1.0.56) on Windows 7.
This thread:
Suggests the problem was fixed, but it doesn't appear to be.
This is not a critical problem but considering the amount of people running these tools the extra CO2 created globally by this "idle" application must be staggering.
Peter.
5 Replies 5
Ammar Malik
He are seeing this issue and we are running 31.3. Has anyone found a solution to this issue?
We are also seeing other PC's with a ptService Module issue. Anyone know what might be causing that service to stop?
Curtis Cai
Thanks for bringing up this issue, Eng team will investigate and update later.
Curtis Cai
Hi, Peter, this issue has been reproduced by Eng, they are doing research to see how to fix it, will keep you posted.
Curtis Cai
This issue has been fixed in T31.6 PT release, but I'm afraid it will take a while to the site you are using.
Ammar Malik
Thanks Wei!
