Agent State Trace does not include Not Ready Codes
Gerry O'Rourke
I have Agent State Trace enabled for a specific number of agents.
The Agent State Trace Report (and I also reviewed the Agent State Trace Table) does NOT contain the Not Ready Events.
The Not Ready Events ARE included in the Event Detail Table, but I would also expect to see them in the Agent State Trace table / report.
Does anyone have any ideas why this might be the case?
Version: ICM 8.0(3)
Gerry
Jameson,
Thanks for your help with this one. The root cause is that this issue is caused by a bug.
My coillegue opened up a TAC case and here is the bug details.
https://tools.cisco.com/bugsearch/bug/CSCtn14139
Fixed with ICM8.0.3_ES7.exe
Gerry
Gerry,
Is it missing "EventName=2" lines entirely, or is it just not getting Reason Codes? I'm seeing Not Ready events in mine, running ICM 8.5.
-Jameson
-Jameson
Jameson,
There are no rows with EventName='2' or AgentState='2'
Lots of rows with EventName = 4,9,10,11,1 etc.
But no Not Ready Rows at all....
Gerry
Well now that is strange. I would check this registry setting:
HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\ICM\{Instance name}\Distributor\RealTimeDistributor\CurrentVersion\Logger\CurrentVersion\HistoricalData\Agent\EventDetail
It should be a REG_DWORD with value of 1. Checking it on every Logger and HDS wouldn't hurt. Have you looked for the EventName='2' rows on the Loggers and B-side HDS, or just your A-side HDS? What are your agents using for CTI? What kind of agent PG are you using?
-Jameson
-Jameson
Jameson,
Gerry
