I need to send a DTMF string when I click a button
Patrick Curley
I have created a gadget using Finesse 10.5(1). What is the correct syntax to send a DTMF string?
I am trying to send the DTMF string while on a call. When I run this code nothing happens; not even an error in the web console.
This is what I have so far:
function testMe() {
    m_dialogObject.diag  = getActiveDialog();
    if (m_dialogObject.diag==null){
        clientLogs.log( "Null dialog");
        return;
    m_dialogObject.diag.sendDTMFRequest(user.getExtension(), 'SEND_DTMF(1)', {
        success : SSTSuccess,
        error: SSTError
SSTSuccess = function(rsp) {
    clientLogs.log( "In test response success; status: " + rsp.status);
    if ( rsp.status == '202' ) {
SSTError = function(rsp) {
        clientLogs.log( "In test response error");
        clientLogs.log( rsp );
Any thoughts are appreciated.
dekwan
Hi Patrick,
Sorry, looks like the JSDoc is incorrect. I looked at the finesse.js file and saw the following:
sendDTMFRequest: function (mediaAddress, handlers, digit) {
where mediaAddress is the user's extension (user.getExtension() like you already have), handlers (just like what you have as well), then digit which is the number that is pushed.
I will open a doc defect for the incorrect JSDoc. I hope this helps.
Thanx,
Denise
dekwan
Hi Patrick,
Thanx,
Denise
