Clustered Firepower Chassis's Management port is not connected !!
mohanB
When I checked the interface status of ETH1/1 on FXOS CLI, it says port is not connected and it is supposed to be the management interface of ASA. Whom to contact to correct this?
jokearns1
Hi Mohan
We will check the interface this morning and get back to you.
Joe
Sent from my Samsung Galaxy smartphone.
Hi Mohan,
I checked the reservations this morning and your reservation ended earlier today.
Can you reserve the Firepower clustered chassis topology again? Once it is up we can look at your issue.
Joe
I tried to use the ASA clustering on the Firepower Chassis Manager lab. Tried multiple different things to bring clustering in the second box, 10.10.20.31.
1. I remove Eth1/1 as the management interface of ASA and added only Eth1/4 as it was the working port.
2. When trying to join the existing cluster on 10.10.20.31, Firepower Chassis Manager, I was receiving following errors.
3. Port type were similar to the 10.10.20.30 box, but for some reason it was constantly throwing this error.
Hi Sailendra,
Apologies for the delayed response on this one. We are currently investigating this and it may require that we baseline the lab again.
We will get back to you shortly with an update.
Joe
