DevNet sandbox not able to connect with provided Lab Network Address
anjelo421
I'm having issue with connecting from cisco anyconnect client.
lab network address:  devnetsandbox-emea-gwy.cisco.com:20193
issue: "connection attempt has timed out, please verify internet connectivity"
Please help
i verified everything and firewall not blocking at all still i'm having
the same issue " connection attempt has timed out, please verify internet
connectivity"
it's used to work perfectly when i had this address
*devnetsandboxlabs.cisco.com/rave39
8 Replies 8
zowu
Hi Anjelo,
I've tried the AnyConnect link and it is working here. Could you please check:
- Can devnetsandbox-emea-gwy.cisco.com be resolved as 173.38.221.89
- Any firewall in your PC or corporate network
You can check VPN logs to see which step is blocked.
Bob
connectivity"
I recommend that you cancel your current reservation and try another.
Craig
Unfortunately I have the same problem with devnetsandbox-emea-gwy.cisco.com:20xxx
I did a packet capture, the TCP handshake successful, then the client initiate the SSL with Client Hello...no response from server.
Tried to delete the lab, recreate it, same issue.
Just to give an update on this. Not sure if it's just an unfortunate case or a continuous problem.
Cheers,
Calin
jasarmie
I have the same problem with this domain, when I was assigned another name It worked well, but two times I received devnetsandbox-emea-gwy.cisco.com:20XXX and it has been imposible to connect.
Same behavior, the client send hello SSL and not anwser.
I am having the exact same issue and same symptoms to devnetsandbox-emea-gwy.cisco.com:20215
Karim-Paris
You should verify your current timezone, before starting the lab.
I suspect that Cisco's Sandbox environment doesn't have adequate resources to handle the load. Its a recurring issue.
