Sandbox Learning Labs issue - ACI Programmability Options
c1sc0d1sc0
Hi all,
I'm stuck with a problem on ACI Programmability Options lab, section APIC Sandbox Environment Setup, it says:
# From within the correct virtual environment (venv) apic_fabric_setup\ $ python baseline.py
# Expected Output
Baselining APIC Simulator for Learning Labs
Setting up Fabric Nodes
Configuring Fabric Policies
Setting up Common Tenant
Setting up Heroes Tenant
Setting up SnV Tenant
But my output is:
(venv) C:\Python27\aci-learning-labs-code-samples\apic_fabric_setup>baseline.py
Traceback (most recent call last):
  File "C:\Python27\aci-learning-labs-code-samples\apic_fabric_setup\baseline.py", line 11, in <module>
    import startup_script
  File "C:\Python27\aci-learning-labs-code-samples\apic_fabric_setup\startup_script.py", line 225, in <module>
    md.commit(c)
  File "c:\python27\lib\site-packages\acicobra-3.0_1k-py2.7.egg\cobra\mit\access.py", line 63, in commit
    return self._accessImpl.post(configObject)
  File "c:\python27\lib\site-packages\acicobra-3.0_1k-py2.7.egg\cobra\internal\rest\accessimpl.py", line 176, in post
    return self.__parseError(rsp, CommitError, rsp.status_code)
  File "c:\python27\lib\site-packages\acicobra-3.0_1k-py2.7.egg\cobra\internal\rest\accessimpl.py", line 234, in __parseError
    parseXMLError(rsp.text, errorClass, httpCode)
  File "c:\python27\lib\site-packages\acicobra-3.0_1k-py2.7.egg\cobra\mit\xmlcodec.py", line 15, in parseXMLError
    raise errorClass(int(errorCode), errorStr, httpCode)
cobra.mit.request.CommitError: Validation failed: Validation failed for node: 102Overlapping interfaces. Last examined: uni/infra/accportprof-dci-l3out-104
Any ideas what I may have done wrong?
8 Replies 8
yawming
Can you please provide the link of the learning lab content you are following and the link to the sample code repo where you cloned the sample code ?
Yawming
Its this lab:
Cisco DevNet Learning Labs
And I followed the instructions - How To Setup Your Own Computer at the top of the page.
Ta
I just went followed steps on Windows and worked for me.
Can you try it again and if not worked please list all the steps you went through.
I have the same exact problem, here are the steps I took before encountering the error during the baseline.py run, last part of "how to set up your computer" that I followed was to install the acicobra/ acimodel .eggs which worked fine per pip freeze:
(venv) C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\venv\Scripts\cobra-eggs>easy_install -Z acicobra-3.2_1m-py2.7.egg
Processing acicobra-3.2_1m-py2.7.egg
creating c:\python27\cisco_devnet\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.2_1m-py2.7.egg
Extracting acicobra-3.2_1m-py2.7.egg to c:\python27\cisco_devnet\aci-learning-labs-code-samples\venv\lib\site-packages
Adding acicobra 3.2-1m to easy-install.pth file
Installed c:\python27\cisco_devnet\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.2_1m-py2.7.egg
Processing dependencies for acicobra===3.2-1m
Finished processing dependencies for acicobra===3.2-1m
(venv) C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\venv\Scripts\cobra-eggs>easy_install -Z acimodel-3.2_1m-py2.7.egg
Processing acimodel-3.2_1m-py2.7.egg
creating c:\python27\cisco_devnet\aci-learning-labs-code-samples\venv\lib\site-packages\acimodel-3.2_1m-py2.7.egg
Extracting acimodel-3.2_1m-py2.7.egg to c:\python27\cisco_devnet\aci-learning-labs-code-samples\venv\lib\site-packages
Adding acimodel 3.2-1m to easy-install.pth file
Installed c:\python27\cisco_devnet\aci-learning-labs-code-samples\venv\lib\site-packages\acimodel-3.2_1m-py2.7.egg
Processing dependencies for acimodel===3.2-1m
Finished processing dependencies for acimodel===3.2-1m
(venv) C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\venv\Scripts\cobra-eggs>pip freeze
acicobra===3.2-1m
acimodel===3.2-1m
acitoolkit==0.4
arya==1.1.5
asn1crypto==0.24.0
attrs==18.2.0
certifi==2018.8.24
cffi==1.11.5
chardet==3.0.4
click==7.0
cryptography==2.3.1
deepdiff==3.3.0
dominate==2.3.4
enum34==1.1.6
flask==1.0.2
flask-admin==1.5.2
flask-bootstrap==3.3.7.1
flask-cors==3.0.6
flask-httpauth==3.2.4
flask-sqlalchemy==2.3.2
flask-wtf==0.14.2
functools32==3.2.3.post2
gitdb2==2.0.4
gitpython==2.1.11
graphviz==0.9
idna==2.7
ipaddress==1.0.22
itsdangerous==0.24
jinja2==2.10
jsonpickle==1.0
jsonschema==3.0.0a3
markupsafe==1.0
py-radix==0.10.0
pycparser==2.19
pymysql==0.9.2
pyrsistent==0.14.4
requests==2.19.1
six==1.11.0
smmap2==2.0.4
sqlalchemy==1.2.12
tabulate==0.8.2
urllib3==1.23
visitor==0.1.3
websocket-client==0.53.0
werkzeug==0.14.1
wtforms==2.2.1
(venv) C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\venv\Scripts\cobra-eggs>cd ..
(venv) C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\venv\Scripts>cd ..
(venv) C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\venv>cd ..
(venv) C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples>cd apic_fabric_setup
(venv) C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\apic_fabric_setup>dir
Volume in drive C is OSDisk
Volume Serial Number is 1E28-82F3
Directory of C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\apic_fabric_setup
10/04/2018 03:56 PM <DIR> .
10/04/2018 03:56 PM <DIR> ..
10/04/2018 03:13 PM 315 baseline.py
10/04/2018 03:13 PM 3,407 create_snv_apps.py
10/04/2018 03:13 PM 82 credentials.py
10/04/2018 03:13 PM 250 requirements.txt
10/04/2018 03:13 PM 26,020 startup_script.py
10/04/2018 03:56 PM 19,427 startup_script.pyc
6 File(s) 49,501 bytes
2 Dir(s) 128,970,395,648 bytes free
(venv) C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\apic_fabric_setup>python baseline.py
File "baseline.py", line 11, in <module>
File "C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\apic_fabric_setup\startup_script.py", line 225, in <module>
md.commit(c)
File "c:\python27\cisco_devnet\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.2_1m-py2.7.egg\cobra\mit\access.py", line 63, in commit
File "c:\python27\cisco_devnet\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.2_1m-py2.7.egg\cobra\internal\rest\accessimpl.py", line 176, in post
File "c:\python27\cisco_devnet\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.2_1m-py2.7.egg\cobra\internal\rest\accessimpl.py", line 234, in __parseError
File "c:\python27\cisco_devnet\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.2_1m-py2.7.egg\cobra\mit\xmlcodec.py", line 15, in parseXMLError
cobra.mit.request.CommitError: Validation failed: Validation failed for node: 102Overlapping interfaces. Last examined: uni/infra/accportprof-Demo-Ins-Pf
I had the same problem on my Mac and gave up on it last night. I got back from work this morning and tried again before my Mac established internet access and it worked. I don't know if that helps anyone but decided to share incase someone wants to try it.
i saw your comment but it was hard to believe that it will work, still i tried to run again and it worked when i run after 10 hours even i didn't make any changes to make it possible.
moca979
If it's any help to someone, I ran into a this issue as well. Output below:
File "/home/moca/devnetlab/aci-learning-labs-code-samples/apic_fabric_setup/startup_script.py", line 225, in <module>
md.commit(c)
File "/home/moca/devnetlab/aci-learning-labs-code-samples/venv/lib/python2.7/site-packages/acicobra-3.0_1k-py2.7.egg/cobra/mit/access.py", line 63, in commit
File "/home/moca/devnetlab/aci-learning-labs-code-samples/venv/lib/python2.7/site-packages/acicobra-3.0_1k-py2.7.egg/cobra/internal/rest/accessimpl.py", line 176, in post
File "/home/moca/devnetlab/aci-learning-labs-code-samples/venv/lib/python2.7/site-packages/acicobra-3.0_1k-py2.7.egg/cobra/internal/rest/accessimpl.py", line 234, in __parseError
File "/home/moca/devnetlab/aci-learning-labs-code-samples/venv/lib/python2.7/site-packages/acicobra-3.0_1k-py2.7.egg/cobra/mit/xmlcodec.py", line 15, in parseXMLError
cobra.mit.request.CommitError: Validation failed: Validation failed for node: 101Overlapping interfaces. Last examined: uni/infra/accportprof-Switch101-102_Profile_ifselector
My solution was to go to the APIC GUI -> Fabric -> Access Policies -> Interfaces -> Leaf Interfaces -> Profiles and delete the entry related to the last line of my error output (I think it was just Switch101-102). The baseline script worked after that. The thing is I broke a lot of stuff in the APIC before I found that setting so it should be interesting to see how my lab works now, but it was fun :)
