04-28-2015 09:53 PM
I am new in the community. I want to run a custom built Java Application in Cisco 3270 Rugged Integrated Services Routers (ISR). Is it possible? If possible, then how to proceed?
05-03-2015 09:39 PM
I don't think Java is supported in Cisco 3270 ISR. You may use CGR1120/1240 or C819-4G to run Java application if possible. Both of CGR1120/1240 and C819-4G supports Cisco IOx which is an application platform for fog computing and supports to run the applications such as data aggregation, control systems, and access control on edge network devices.
Steve
05-03-2015 10:41 PM
Thanks. It helps.
-- Abedin
