08-04-2016 02:09 PM
While understanding that there are existing serial ports on IR829, I am wondering whether USB port can be used for serial connectivity into GOS.
08-06-2016 12:15 AM
Hi David,
Currently the USB port is only available as USB storage for GOS. It may support USB Serial or other in later version.
As you mentioned, you may use the two serial interfaces of IR809 directly currently.
Steve
Log in to Community
