LXC type application on IR809
bharat3
I am using IR809 router with "IOx bundle image of ir800-universalk9-bundle.SPA.156-2.T1" and the Guest OS installed by default with the bundle.
I am using the  SDK 1.1.0 for application development. I am following LXC Applicaton Development on Cisco IR829 IOx.pdf guide to develop a LXC application.
So far I have successfully developed and installed PaaS on IR809. But with the LXC type application I am unable to install. I am trying to install the sample application "nt02-c_simple" provided with the SDK (demo-apps).
I get the following error while installing
bharath@bharath-Vostro-2520:$ioxclient app install nt02 nt02-c_simple_ir800-lxc.tar
Currently active profile :  new
Command Name: application-install
Saving current configuration
Could not complete your command :  Error. Server returned 500
"description": "{\"total_errors\": 1, \"error_list\": [{\"message\": \"{'cpuarch': 'x86_64', 'kernel-version': '3.19', 'startup': {'target': '/sbin/init', 'rootfs': 'app.ext2'}, 'resources': {'profile': 'custom', 'memory': 64, 'disk': 2, 'network': [{'interface-name': 'eth0'}], 'cpu': 500}, 'type': 'lxc'} is not valid under any of the given schemas\", \"validator_value\": \"[{'$ref': '#/definitions/__main__.AppPaas'}, {'$ref': '#/definitions/__main__.AppLXC'}, {'$ref': '#/definitions/__main__.AppVM'}]\", \"absolute_path\": \"app\", \"absolute_schema_path\": \"properties/app/oneOf\"}]}",
"errorcode": -1025,
"message": "Error during app installation"
I checked the .yaml file (attached) with the descriptor-schema-version 2.0 specifications at this github document and devnet document. But found no errors in there.
I am not sure what else to debug.
Any help with this is much appreciated.
Bharath
Steve Zhang
Please install the GOS image of the IOXVM 1.1.0 below.
IOx  VM (GOS) Image 1.1.0 for IR829:
https://software.cisco.com/download/release.html?i=!y&mdfid=286287094&softwareid=286306224&release=1.1.0&os
