No IP from bridge network on IOx
Hi, i'm having trouble getting an IP for an IOx application using bridge network while it works correctly on the NAT interface.
DHCP pool is correctly configured but only the Local manager is getting the IP from that.
I've attached a tech support report.
Giuseppe
I've roller back to iox image 1.1 and DHCP is now correctly working... Is there any known issue with iox 1.3?
Giuseppe
It is a known issue for version 1.3. and team is fixing it and will release a new version soon.
As a workaround, you may reload your 829/809, or restart GOS with "guest-os 1 restart". Hope it helps.
I also got another recommandation
IR800-GOS-1:~#
IR800-GOS-1:~# rm /software/caf/work/network/.nuuid
IR800-GOS-1:~#
IR800#guest-os 1 restart
