rommon-2, IR809
I have a problem with the IR809G. The router stucks in the rommon-2.
This is the output in putty:
<3> [0.753643] IOAPIC: IOAPIC 1 initialized, implementation version 32
<3> [0.753643] <E1000> e1000_device_init: initialized E1000 device
<6> PCI: Initializing
<6> PCI: Finished Initializing
Autoboot string flash:/ir800-universalk9-mz.SPA.156-3.M2,12;
Failed to boot, skip first flash:/ir800-universalk9-mz.SPA.156-3.M2,12;
rommon-2> dir
flash:
rommon-2>
rommon-2>
How can I copy the IOS-image from rommon-2?
Thanks for your help!
5 Replies 5
Steve Zhang
Did you see the post of Re: How to Boot to IOS from rommon-2, and Not Have to do That Again?
If there is the image file of "ir800-universalk9-mz.SPA.156-3.M2" in flash:, you may simple run: rommon-2> boot flash:/ir800-universalk9-mz.SPA.156-3.M2 to boot IR809. or, please use TFTP to copy the image to IR809 first.
use the command below to TFTP copy first to flash:
rommon-> tftp 10.1.11.12.13 /tftpboot/ir800-universalk9-mz.SPA.156-3.M2 flash:
You may use help to see what exact command it it. the basic idea is to use tftp to copy the image to Flash:.
change from Rommon-2 to Rommon-1:
Try Ctrl-C while reboot the system. It worked for me on IR829.
Steve Zhang
For how to use the commands at rommon-1 and 2, you may refer to Rommon Recovery Procedure for the Cisco IR800 Industrial ISR - Cisco
