7921 not picking up new firmware?
gkonheiser
Hi There
I am having a problem geting my 7921 to pickup new firmware. In my config I have:-
tftp-server flash:WLAN-1.4.3SR1.2.SBN
tftp-server flash:TNUXR-1.4.3SR1.2.SBN
tftp-server flash:TNUX-1.4.3SR1.2.SBN
tftp-server flash:SYS-1.4.3SR1.2.SBN
tftp-server flash:GUI-1.4.3SR1.2.SBN
tftp-server flash:CP7921G-1.4.3SR1.2.LOADS
tftp-server flash:APPS-1.4.3SR1.2.SBN
telephony-service
em logout 0:0 0:0 0:0
max-ephones 58
max-dn 192
ip source-address 192.168.3.100 port 2000
service phone displayIdleTimeout 00:30
service phone displayOnDuration 1:00
timeouts interdigit 8
timeouts ringing 20
cnf-file perphone
network-locale GB
network-locale 1 GB
network-locale 2 GB
network-locale 3 GB
network-locale 4 GB
load 7921 CP7921G-1.4.3SR1.2.LOADS
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone  1
device-security-mode none
mac-address 001F.9E8B.A45F
max-calls-per-button 4
type 7921
ephone-dn  1  dual-line
ring internal
number 1001
Despite this the phone is showing firmware : CP7921G-1.3.4.LOADS
This is the Debug ephone register output:-
25 06:08:01.960: New Skinny socket accepted [2] from 0, sub 1 (3 active)
.Jun 25 06:08:01.960: sin_family 2, sin_port 1024, in_addr 192.168.3.181
.Jun 25 06:08:01.960: skinny_add_socket 2 192.168.3.181 1024
.Jun 25 06:08:02.252: %IPPHONE-6-REG_ALARM: Name=SEP001F9E8BA45F Load=CP7921G-1.3.4 Last=Reset-Reset
Skinny StationAlarmMessage on socket [4] 192.168.3.181 SEP001F9E8BA45F
.Jun 25 06:08:02.252: severityInformational p1=67584 [0x10800] p2=-1258051392 [0xB503A8C0]
.Jun 25 06:08:02.252: Name=SEP001F9E8BA45F Load=CP7921G-1.3.4 Last=Reset-Reset
.Jun 25 06:08:02.461: ephone-(1)[4] StationRegisterMessage (1/1/59) from 192.168.3.181
.Jun 25 06:08:02.461: ephone-(1)[4] Register StationIdentifier DeviceName SEP001F9E8BA45F
.Jun 25 06:08:02.461: ephone-(1)[4] StationIdentifier Instance 1    deviceType 365
.Jun 25 06:08:02.461: ephone-1[0/3]:stationIpAddr 192.168.3.181
.Jun 25 06:08:02.461: ephone-1[0/3][SEP001F9E8BA45F]:maxStreams 0
.Jun 25 06:08:02.461: ephone-1[0/3][SEP001F9E8BA45F]:From Phone raw protocol Ver 0x85600010
.Jun 25 06:08:02.461: ephone-1[0/3][SEP001F9E8BA45F]:protocol Ver 0x85600010
.Jun 25 06:08:02.461: ephone-1[0/3][SEP001F9E8BA45F]:phone-size 58032 dn-size 808
.Jun 25 06:08:02.461: ephone-(1) Allow any Skinny Server IP address 192.168.3.100
.Jun 25 06:08:02.461: ephone-1[0/3][SEP001F9E8BA45F]:Found entry 0 for 001F9E8BA45F
.Jun 25 06:08:02.461: ephone-1[0/3][SEP001F9E8BA45F]:socket change 3 to 4
.Jun 25 06:08:02.461: ephone-1[0/3][SEP001F9E8BA45F]:DisAssociate: Closed socket 3 while REGISTERED
.Jun 25 06:08:02.461: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-1:SEP001F9E8BA45F IP:192.168.3.181 Socket:3 DeviceType:Phone has unregistered abnormally.
.Jun 25 06:08:02.461: ephone-1[0/-1][SEP001F9E8BA45F]:FAILED: CLOSED old socket -1
.Jun 25 06:08:02.461: ephone-1[0/4][SEP001F9E8BA45F]:phone SEP001F9E8BA45F re-associate OK on socket [4]
.Jun 25 06:08:02.461: %IPPHONE-6-REGISTER: ephone-1:SEP001F9E8BA45F IP:192.168.3.181 Socket:4 DeviceType:Phone has registered.
.Jun 25 06:08:02.461: Phone 0 socket 4
.Jun 25 06:08:02.461: Skinny Local IP address = 192.168.3.100 on port 2000
.Jun 25 06:08:02.461: Skinny Phone IP address = 192.168.3.181 1024
.Jun 25 06:08:02.465: ephone-1[0/4][SEP001F9E8BA45F]:Signal protocol ver 12 to phone with ver 16
.Jun 25 06:08:02.465: ephone-1[0/4][SEP001F9E8BA45F]:Date Format M/D/Y
.Jun 25 06:08:02.465: ephone-1[0/4]:RegisterAck sent to sockettype ephone socket 4: keepalive period 30 use sccp-version 12
.Jun 25 06:08:02.465: ephone-1[0/4]:CapabilitiesReq sent
.Jun 25 06:08:02.501: ephone-1[0/4]:CapabilitiesRes received
.Jun 25 06:08:02.501: ephone-1[0/4][SEP001F9E8BA45F]:Caps list 13
G711Ulaw64k  60 ms, is_mtp 0
G711Alaw64k  60 ms, is_mtp 0
Unrecognized Media Type 257  60 ms, is_mtp 0
G729  60 ms, is_mtp 0
G729AnnexA  60 ms, is_mtp 0
G729AnnexB  60 ms, is_mtp 0
G729AnnexAwAnnexB  60 ms, is_mtp 0
WideBand_256K  120 ms, is_mtp 0
G722_64k  120 ms, is_mtp 0
G722_56k  120 ms, is_mtp 0
G722_48k  120 ms, is_mtp 0
ILBC  60 ms, is_mtp 0
.Jun 25 06:08:02.709: ephone-1[0/4]:ButtonTemplateReqMessage
.Jun 25 06:08:02.709: ephone-1[0/4][SEP001F9E8BA45F]:StationButtonTemplateReqMessage set max presentation to 2
.Jun 25 06:08:02.709: ephone-1[0/4]:CheckAutoReg
.Jun 25 06:08:02.709: ephone-1[0/4]:AutoReg is disabled
.Jun 25 06:08:02.709: ephone-1[0/4][SEP001F9E8BA45F]:Setting 6 lines 0 speed-dials on phone (max_line 6)
.Jun 25 06:08:02.709: ephone-1[0/4][SEP001F9E8BA45F]:First Speed Dial Button location is 0 (0)
.Jun 25 06:08:02.709: ephone-1[0/4]:ButtonTemplate lines=6 speed=0 buttons=6 offset=0
.Jun 25 06:08:02.709: ephone-1[0/4][SEP001F9E8BA45F]:ButtonTemplate buttonCount=6 totalButtonCount=6 buttonOffset=0
.Jun 25 06:08:02.709: ephone-1[0/4][SEP001F9E8BA45F]:Configured 0 speed dial buttons
.Jun 25 06:08:02.721: ephone-1[0/4]:StationSoftKeyTemplateReqMessage
.Jun 25 06:08:02.721: ephone-1[0/4]:StationSoftKeyTemplateResMessage
CME3.100(config-ephone)#
.Jun 25 06:08:02.825: ephone-1[0/4]:StationSoftKeySetReqMessage
.Jun 25 06:08:02.825: ephone-1[0/4]:StationSoftKeySetResMessage
.Jun 25 06:08:02.937: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatReqMessage from ephone line 6
.Jun 25 06:08:02.937: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatReqMessage from ephone line 6 Invalid DN -1
.Jun 25 06:08:02.937: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatResMessage sent to ephone (1 of 6)
.Jun 25 06:08:03.057: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatReqMessage from ephone line 5
.Jun 25 06:08:03.057: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatReqMessage from ephone line 5 Invalid DN -1
.Jun 25 06:08:03.057: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatResMessage sent to ephone (2 of 6)
.Jun 25 06:08:03.213: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatReqMessage from ephone line 4
.Jun 25 06:08:03.213: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatReqMessage from ephone line 4 Invalid DN -1
.Jun 25 06:08:03.213: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatResMessage sent to ephone (3 of 6)
.Jun 25 06:08:03.317: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatReqMessage from ephone line 3
.Jun 25 06:08:03.317: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatReqMessage from ephone line 3 Invalid DN -1
.Jun 25 06:08:03.317: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatResMessage sent to ephone (4 of 6)
.Jun 25 06:08:03.429: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatReqMessage from ephone line 2
.Jun 25 06:08:03.429: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatReqMessage from ephone line 2 Invalid DN -1
.Jun 25 06:08:03.429: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatResMessage sent to ephone (5 of 6)
.Jun 25 06:08:03.537: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatReqMessage from ephone line 1
.Jun 25 06:08:03.541: ephone-1[0/4]:CheckAutoReg
.Jun 25 06:08:03.541: ephone-1[0/4]:AutoReg is disabled
.Jun 25 06:08:03.541: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatReqMessage from ephone line 1 Invalid DN -1
.Jun 25 06:08:03.541: ephone-1[0/4][SEP001F9E8BA45F]:StationLineStatResMessage sent to ephone (6 of 6)
.Jun 25 06:08:03.541: ephone-1[0/4]:SkinnyCompleteRegistration
.Jun 25 06:08:04.009: ephone-1[0/4][SEP001F9E8BA45F]:Skinny Available Lines 6 set for socket [4]
.Jun 25 06:08:04.009: ephone-1[0/4]:Already done SkinnyCompleteRegistration
.Jun 25 06:08:04.149: ephone-1[0/4]:HeadsetStatusMessage
.Jun 25 06:08:07.673: New Skinny socket accepted [2] from 0, sub 1 (1 active)
.Jun 25 06:08:07.673: sin_family 2, sin_port 1026, in_addr 192.168.3.181
.Jun 25 06:08:07.673: skinny_add_socket 2 192.168.3.181 1026
I am using CME 7.1. Any help much appriciated.
5 Replies 5
Jonathan Schulenberg
Did you regenerate the CNF files? The LOADS file is referenced within the SEPDefault.xml.cnf and SEP.xml.cnf which must be manually rebuilt after making a config change that impacts them.
telephony-service
  create cnf-files
Please remember to rate helpful responses and identify helpful or correct answers.
I just tryed that and a reset but no joy, still has the old firmware, thanks anyway.
Just checked the admin guide. None of the examples shown include the ".LOADS" extension in the load command. Try changing to 'load 7921 CP7921G-1.4.3SR1.2' instead and then regenerate CNF files.
Hi Jonathan,
That was it great!  Thanks.
When I do sh telephony-service tftp-bindings I dont see a config file for the 7921, thats not normal is it? Here is the out put,
tftp-server system:/its/united_kingdom/7960-tones.xml alias United_Kingdom/7960-tones.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/7960-font.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/7920-font.xml
tftp-server system:/its/united_states/7960-dictionary.xml alias English_United_States/7960-dictionary.xml
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/7960-kate.xml
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/7920-kate.xml
tftp-server system:/its/united_states/SCCP-dictionary.xml alias English_United_States/SCCP-dictionary.xml
tftp-server system:/its/vrf1/SEP001F9E8BA45F.cnf.xml alias SEP001F9E8BA45F.cnf.xml
tftp-server system:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
tftp-server system:/its/vrf1/XMLDefault.cnf.xml alias XMLDefault.cnf.xml
cmaiolani
i can see the correct file with 7921 MAC. you can check with debug tftp events if phone miss one file or if there is other problems.
