Can't configure alternative ringtones for SIP lines on IP Phone 7962
Blacky42
Dear all,
I've managed to get the ringlist.xml working for the default tone menu/entry (sorry if the name doesn't fit exactly since I'm using the German locale) via TFTP server.
However if I try to select one of my two configured SIP lines and want to select another ring tone here the phone says that ringlist is not available.
Any idea what I can do?
Do I need to create further ringlist.xml files for each individual SIP line (and if so how should I  name them?)?
Thanks for your hints.
Cheers
Blacky42
R0g22
Ringlist.xml is for the phone as a whole. If you are trying to change the ring tones on a per line basis, then DistinctiveRinglist.xml is the file that needs to be tweaked.
R0g22
Brilliant hint - thanks a lot!
I've just copied my ringlist.xml and renamed it to distinctiveringlist.xml (all in small letters). Now it's working well.
