Cause i = 0x82E6 - Recovery on timer expiry
jfrackiewicz
we are experiencing a problem with external incoming calls. When our customer is in active call and somebody wants to call him from a mobile phone (like Vodafone etc.) it takes a long time until we get a error on the H323 gateway.
Aug 20 13:01:38.696 GMT: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x447C
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98386
                Exclusive, Channel 6
        Calling Party Number i = 0x2183, '170792xxx'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '85794xxxx'
                Plan:ISDN, Type:Subscriber(local)
        High Layer Compat i = 0x9181
Aug 20 13:01:38.696 GMT: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0xC47C callID = 0x0225 switch = primary-net5 interface = User
Aug 20 13:01:38.700 GMT: ISDN Se0/1/0:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0xC47C
Aug 20 13:01:39.700 GMT: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xC47C
Aug 20 13:02:09.703 GMT: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0xC47C
        Cause i = 0x8090 - Normal call clearing
Aug 20 13:02:09.715 GMT: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x447C
Aug 20 13:02:09.715 GMT: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xC47C
Aug 20 13:02:09.719 GMT: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x447C
If the call comes from a "fix" external phone (like Telekom etc.) not a mobile phone we get a busy response.
Aug 20 13:05:01.347 GMT: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x3871
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9838D
                Exclusive, Channel 13
        Calling Party Number i = 0x2180, '699xxxxx'
        Calling Party Number i = 0x2183, '699xxx'
        Called Party Number i = 0xC1, '857xxxxxx'
Aug 20 13:05:01.347 GMT: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0xB871 callID = 0x022C switch = primary-net5 interface = User
Aug 20 13:05:01.351 GMT: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xB871
Aug 20 13:05:01.363 GMT: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0xB871
        Cause i = 0x8091 - User busy
Aug 20 13:05:01.431 GMT: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x3871
Aug 20 13:05:01.431 GMT: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xB871
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn switch-type primary-net5
 isdn overlap-receiving T302 2500
 isdn incoming-voice voice
 isdn send-alerting
 isdn sending-complete
 no cdp enable
interface Serial0/1/0:15
 no ip address
 encapsulation hdlc
 isdn send-alerting
 no cdp enable
It think this is a telco problem. Since the problem persist since the last week and there was a telco migration.
15 Replies 15
Brian Meade
Level 7
Level 7
Are you using CUCM or CME?  If CUCM, what does your dial-peer config look like?
We are using CUCM 8.6.2.
dial-peer voice 100 voip
 preference 2
 destination-pattern 498985794T
 no modem passthrough
 session target ipv4:172.xx
 voice-class codec 10
 voice-class h323 10
 dtmf-relay h245-alphanumeric
 playout-delay fax 40
 no fax-relay sg3-to-g3
 fax rate 9600
 fax nsf 000000
 fax protocol t38 version 0 ls-redundancy 1 hs-redundancy 1 fallback none
 ip qos dscp cs3 signaling
 no vad
dial-peer voice 110 voip
 preference 4
 voice-class h323 10
 fax rate 9600
 fax nsf 000000
 no vad
dial-peer voice 999 voip
 incoming called-number .
 dtmf-relay h245-signal h245-alphanumeric rtp-nte
 no vad
dial-peer voice 998 voip
 no vad
Can you collect CallManager traces set to Detailed and attach them for both call examples?
j.huizinga
Level 6
Level 6
Normally is layer 2 issue.
Can you debug isdn q921?
Jan
Sreekanth Narayanan
I think we need to see the behavior of the gateway on the other leg, h323. Maybe there's a difference in the way the call is being handled in the 2 cases. Let's take debugs on the other side too.
debug voip ccapi inout
debug h225 asn1
debug h245 asn1
debug cch323 h225
debug cch323 h245
We found something -> Can someone tell me where the FinalDestinationFlag is set/generated? On Voicegateway side or provider side?
I believe FinalDestinationFlag is set to True when there's only one matching outbound dial-peer.  Can you post a full "debug voice ccapi inout" output so we can see if it tries another outgoing dial-peer in the failed scenario?  I'm guessing the issue is going to be related to the failed call hunting to another dial-peer when getting the user-busy.  Please also get the above debugs as requested by Sreekanth so we can see if the other side is actually sending user busy in both cases.
Attached I have the
Debug h225 asn1
Debug  h245 asn1
Debug voice ccapi inout
Currently I am not on site to do the other debugs.
Please also add "debug isdn q931" and "debug cch323 all" and collect again with all.
Also turn on "service sequence-numbers", disable console and monitor logging, and set up a logging buffer.
conf t
 no logging console
 no logging mon
 logging buffer 5000000 debug
then do clear log and collect the log by running "show log".  This method will ensure no messages are missed and also make sure you don't crash the router with intensive debugs.
Hi Guys,
I'm a colleague of the initiator(jfrackiewicz), please find attached "debug isdn q931" and "debug cch323 all" as requested
        Calling Party Number i = 0x2183, '1707923821'
        Called Party Number i = 0xC1, '8579453047'
We are fairly sure that is it no call manager issue, due to the fact, that we have a h323 gateway that sends a "setup_ack" 4 milliseconds after receiving the "setup" from the provider, we assume that everything "interesting" happens on the voice gateway.
Some time ago he had a look on the call manager traces and couldn't find anything that could help.
Also we are a bit confused what causes the issue, because it is just happening since the provider change and the busy tone fails provider based: for example Vodafone works not, Deutsche Telekom does. So primarily we try to find out whats the difference at incoming calls.
Thanks to all for the feedback
Kind Regards
Daniel
Please collect all the requested debugs for working and non-working.  These timestamps don't match the other debugs.
Hi Brian,
Sorry for the delay. I attached the requested debugs in "failed" and "success". Thank you
failed(Vodafone):
Calling 170792067
Called 49898579453047
success(O2):
Calling 15140036928
SDESTOVGW01#sh debugging
H.225:
  H.225 ASN1 Messages debugging is on
H.245:
  H.245 ASN1 Messages debugging is on
CCH323 SPI: H225 State Machine tracing is enabled (filter is OFF)
CCH323 SPI: H245 State Machine tracing is enabled (filter is OFF)
CCAPI:
  debug voip ccapi inout is ON (filter is OFF)
Please also include "debug isdn q931".
For the failed scenario, it looks like direct-inward-dial isn't working.
It seems to generate dialtone to the caller:
204796: Aug 25 17:28:02.275 GMT: //30842/3C81266C8E85/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=30842
It then waits until it receives a digit from the user:
204843: Aug 25 17:28:04.775 GMT: //30842/3C81266C8E85/CCAPI/cc_api_call_info:
   Info Digits=, Info Complete=TRUE,
   Interface=0x14A4DA8C, Data Bitmask=0x0, Call Id=30842
204844: Aug 25 17:28:04.775 GMT: //30842/3C81266C8E85/CCAPI/ccCallReportDigits:
   (callID=0x787A, digit_event=0x0, enable=FALSE, consume=FALSE)
Why don't you have an incoming dial-peer configured?  These calls are hitting dial-peer 0 incoming which is never good.  You need to set up an incoming POTS dial-peer with direct-inward-dial enabled.
Thats exactly the point, we found out that the incoming dial-peer didnt work properly.
We have configured a new one with "incoming called-number" instead of a "destination-pattern"(+DID) and it seem to work fine. Thanks for the explanation and confirmation.
But we still don't know why the different Calling Parties from external are treated in a different way when the signaling from the provider looks exactly the same.
