CDR 10021 There are no matching records
bluesea2010
Level 5
Level 5
I am getting the CDR error  like below
Verified under service parameters  , cdr flag enabled True
Please help
CUCM 11.5
8 Replies 8
Jonathan Schulenberg
You must enable CDR on each cluster node that is running the CallManager service; that Service Parameter is not cluster-wide.
hi,
yes enabled on both node . I have only both node
Is CAR loading the CDR flat files generated by CCM?
How to verify this ?
CDR load is enabled ,under scheduler daily weekly monthly  are set
This is what i got  in event log
Jobs : CDR Load
Status: Complete;In Progress;Interrupted;Unsuccessful;Scheduled
From Time: Jul 1, 2020 00:00:00    To Time: Jul 6, 2020 10:29:39
Sl No Jobs Start Time End Time Status Date
1 CDR Load Jul 1, 2020 20:45:06 Jul 2, 2020 20:45:09 Complete Jul 1, 2020
2 CDR Load Jul 2, 2020 20:45:09 Jul 3, 2020 20:45:05 Complete Jul 2, 2020
3 CDR Load Jul 3, 2020 20:45:05 Jul 4, 2020 20:45:08 Complete Jul 3, 2020
4 CDR Load Jul 4, 2020 20:45:08 Jul 5, 2020 20:45:03 Complete Jul 4, 2020
CDR Load Jul 5, 2020 20:45:03 _ In Progress Jul 5, 2020
Restarting the service will help ? Any pros and cons in restarting .
If no What services need to be restarted and How can I do that in gui
Hi @Jonathan Schulenberg
Please  help
Did you got it fixed? I am having same issue after the Call manager is upgraded to 12.5.1 SU8a from 11.5.1 SU7.
Rebooted the publisher and checked the CDR enabled flag on all servers and restarted the related CDR services
bluesea2010
Level 5
Level 5
it was certificate issue for me
