06-24-2011 02:32 PM - edited 03-16-2019 05:37 AM
Hi everybody,
I am gettig the CDR reports. I have a VIC card with 4 ports installed in a CME 2800 but I havent found how to identify which calls go out from one port and which ones go out from the other. What I´ve found are the interpretetion Call Termination Cause Codes
I have the CDR attached.
06-24-2011 02:50 PM
are these ports added as mgcp gateways ? may be you may want to run a gateway report..
06-27-2011 02:05 PM
The CDR are sent to a syslog server . Cell phone calls go out from one port(VIC card) only and local, LD, cell phone (second preference) go out from the other(VWIC T1/E1 card). For billing purposes I want to know how many calls go out from each port and from each case.
Is there any way to figure out this?
When I open the CDR logs I get the attached file.
And yes these ports are added to an MGCP gateway.
