CUE Module with zero Disk Space
Gabriel Ruiz
I have an issue with a 2911 Router w/ CUE. When I run the following command:
service-module embbeded-service-engine 0/0 status
I get the following output:
CPU FREQUENCY: 500MHz
Memory Size: 256MB
Disk Size: 0 MB
I try to install the unity express software it downloads the initial install files but the I get a bad magic number error and disk partition error and the install get stuck. We tried this with 2 NME and 1 ISM and same thing. I either have really bad luck or I'm missing something here. TAC wants to RMA the unit everytime I call them but its already the 3rd Module.  Let me know if someone has seen this issue before. Thanks.
thisisshanky
Level 11
Level 11
is the CUE data already backed up?  Have you tried taking CUE offline, restore the module to factory defaults ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Brand new system. Out of the box.
what version is running in the box ?
Sankar Nair
can you do a sh inventory and tell the exact part...
Sankar Nair
