Computer Unidentified network issues when Behind IP Phone
ziqex
Level 4
Level 4
We came across weird issues. Computers connected to Switch are not working correctly when connected via cisco desk phone - showing unidentified network. Without desk phone computers working fine. Issue started +- a week ago.
port config
interface GigabitEthernet1/0/22
switchport access vlan 20
switchport mode access
switchport nonegotiate
switchport voice vlan 40
switchport port-security maximum 2
switchport port-security violation restrict
switchport port-security aging time 2
switchport port-security aging type inactivity
spanning-tree portfast
spanning-tree bpduguard enable
Phone type: CP-8841
More than one computer & desk phone is impacted.
switch - cisco WS-C3850-48P - 16.12.07
CUCM - System version: 14.0.1.12900-161
Any suggestion's will be highly appreciated. Thank you
19 Replies 19
balaji.bandi
You have tried removing the Phone the PC works, Have you tried  Phone alone  without PC ? is the phone works.
For testing remove the Security configuration and test it or increase the maximum to 5 and age timing to higher.
BB
Phone connected on its own is working fine. Tested with internal and external calls.
Port-security was changed.
switchport port-security maximum 5
switchport port-security aging time 5
So by changing to 5 is that fixed or still have issue.
if that is resolved make this as solution.
BB
Still the issue.
ok can you post show interface configuration again.
other question  in week time what was changed ? any DHCP changes ?
PC get IP address from right VLAN ? are you able to ping Local Gateway  and 8.8.8.8 ?
BB
No changes to the network.
Stack of 4 switches. Only one switch is impacted (*1 Active).
Switch# Role Mac Address Priority Version State
*1 Active  12 V05 Ready
2 Standby  11 V07 Ready
3 Member  10 V07 Ready
4 Member  9 V07 Ready
Please reload switch 1 than send the output of a show port security and a show version
Carlo
Please rate all helpful posts "The more you help the more you learn"
Port security was disabled but the same issue present:
sh port-security int g1/0/22
Port Security : Disabled
Port Status : Secure-down
Violation Mode : Shutdown
Aging Time : 0 mins
Aging Type : Absolute
SecureStatic Address Aging : Disabled
Maximum MAC Addresses : 1
Total MAC Addresses : 0
Configured MAC Addresses : 0
Sticky MAC Addresses : 0
Last Source Address:Vlan : 682c.7b40.7401:640
Security Violation Count : 12
As I can see now the port config has maximum mac set to 1
Please increase the value and perform a shutdown no shutdown for that port
Please let us know
Carlo
Port security is disabled:
port config
To verify the correct behavior of the switch side, you can issue the show port-security command and see if the count of Security Violations increases.
Please let us know.
Carlo
Port Security : Enabled
Port Status : Secure-up
Violation Mode : Restrict
Aging Time : 5 mins
Aging Type : Inactivity
Maximum MAC Addresses : 5
Total MAC Addresses : 2
Security Violation Count - doesn't increases
Select one pc and check it mac
The  do
Show mac address  <pc mac>
Show port-secuirty mac
Check if pc show in other ports.
Do you check points I ask?
The show port security show two mac connect
Can I see
Show mac interface x
I need to see which vlan assign for both mac
