IP Phone 7912 G SIP
johnwatson
Hello guys
I try to registering 7912 G as sip phone to CME, I changed the firmware to sip but it doesn't registering to CME
ip dhcp pool VOIC
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
option 150 ip 192.168.100.1
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
ipv4 192.168.100.1
ipv4 192.168.1.106
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
voice class custom-cptone jointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice register global
mode cme
source-address 192.168.100.1 port 5060
max-dn 3
max-pool 3
load 7912 CP7912080001SIP060412A.sbin
tftp-path flash:
file text
create profile sync 0002853230613172
voice register dn 1
number 123
name 123
voice register pool 1
id mac 0011.216D.F87B
number 1 dn 1
Under "voice register pool" you will need to specify the device type with the "type 7912" command.
Also, this looks like a new implementation. Have you sent the "create profile" command under "voice register global"?
Maren
