03-20-2024 07:55 AM
When placing international calls on with the console software, it is adding a 9 before the number. So if the operator dials 901144xxxxxxxxxx the console will dial 9901144xxxxxxxxxxx causing the call to fail. no other phones have this issue.
Registered - Subscribed product DAYS REMAINING: 1784 |
System Version: 12.0.6.10-34 |
Administration Version: 12.0.6.2199 |
Solved! Go to Solution.
03-21-2024 09:29 AM
this had to do with out maximum internal device digit length being set to low see below.
Chapter 8 Configuring cisco unified attendant console Administration guide
External Area Code is required for the External International Access Number to go in to effect.
Otherwise, outbound calls will default to the External Access Number.
Choose User Configuration > General Properties.
Enter the General Properties:
• Internal/External Access—These properties enable Cisco Unified Attendant Console Advanced to
distinguish between internal and external calls:
– Minimum internal device digit length—the minimum number of digits used by an internal
device
– Maximum internal device digit length—the maximum number of digits used by an internal
device
03-20-2024 08:32 AM
03-21-2024 09:29 AM
device
device
