Number cut off on CME
MarcoM
Hi all,
when receive a fax from a number of a customer my cme cut same digits.
For example when receive fax from 271090935 to 331755511, the CME cut two final digits 11 and route a call to internal 01.
This strange event occurs only on some numbers not all incoming fax.
I attached debug of a trace.
Below are some parts of the configuration:
dial-peer voice 101 pots
translation-profile outgoing OUTGOING
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/0/0:15
voice-port 0/0/0:15
input gain -2
echo-cancel coverage 32
cptone IT
bearer-cap Speech
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving T302 1000
isdn incoming-voice voice
isdn send-alerting
isdn negotiate-bchan
no cdp enable
voice translation-rule 101
rule 2 /^\(...\)$/ /03317555\1/
voice translation-profile OUTGOING
translate calling 101
num-exp 331755501.. ..
num-exp 331755501... ...
num-exp 3317555.. ..
num-exp 3317555 01
Anyone help me please?
Thanks in advance.
M
Hi Marco.
Found the issue... remove direct-inward dial from dialpeer 101
Carlo
Please rate all helpful posts "The more you help the more you learn"
30 Replies 30
Hi Marco.
Can you try to modify your T302 value to 5000?
Carlo
Hi Carlo,
i changed value to 5000 but i have same issue.
Hi Marco,
     You have a number expansion command configured :
num-exp 3317555 01
A num-expansion acts before an outbound dial-peer is matched. I havnt had a look at the debugs yet, but that might be kicking in. Although the CME should do a Digit Analysis for the entire digit dialed, which is :
331755511
I shall go over the debugs and let you know, but as a test, is it possible for you to remove that and try a call?
Jagpreet
Hi Jaqpreet,
in the past i tried to delete "num-exp 3317555 01" but i had other issue...i could not reach any phone number on that site.
Marco,
     I understand. I shouldve looked at the debug before replying. Could you also please collect "deb isdn q931" along with "deb voice ccapi inout" and make another test call and share the same?
Jagpreet
Jagpreet,
i collect logs without "num-exp 3317555 01"?
No, with it would be just fine. I dont think thats the issue. Right now, in the initial Digit Analysis, CME does not read the "11". If it were the Num-Expansion, that would kick in after this.
I just want to make sure the incoming digits are good from the PSTN.
Jagpreet
Jagpreet,
attched debugs required.
p.s. there are 2 tabs on file .xls
Let me know.
Thanks.
Marco,
     In the incoming SETUP message from the PSTN, I see the called numbr as :
'3317555'
If we are dialing the correct number, then this is something you should contact the service provider about.
Jagpreet
Please rate helpful posts.
Jagpreet,
yes correct number that i compose is 331755511, but if i call this number from mobile phone it works fine.
What I will ask the provider?
Thanks.
M
Marco,
     Show them the incoming SETUP message from the debug and ask them whats going on.
Jagpreet
phershaw
Marco,
You could try something like this to ensure that you "wait" for the overlap digits before hitting your number expansions.
voice translation-rule 100
rule 1 /^3317555\(..*\)$/ /\1/
voice translation-profile INCOMING
translate called 100
voice-port 0/0/0:15
translation-profile incoming INCOMING
It might also be possible to expand the voice translation-rule above so you don't need to use the number expansions.
Phil
Hi phershaw,
can i try your suggestion, but i must delete my "translation-rule 101" or can i add it without delete?
@Jagpreet Thanks!
Thanks.
Marco
Hi Marco.
Yes you can add it as rule 2 in your translation-rule 101
Carlo
