How to upload a file to a MOH using AXL?
fabien.bonic
Level 5
Level 5
Is there a solution for uploading a file to a MOH on a CUCM using the AXL? If it's not possible, what are the others API to upload a file on a CUCM?
Fabien
Unfortunately, there is currently no programmatic way to upload a MoH file.
TDoan
Hi Fabien,
To update file to MOH, you can use updateMohAudioSource
Hope this would help you,
Thuy Doan
Hi Thuy Doan,
Thanks. In fact I want to "upload a file" (the action button near "save" on the GUI) and not only update the MOH.
Fabien
Thank you for the answer.
