07-21-2016 12:33 PM
Found another one on CUCM 11.5. I was going throgh my remote destination tests, and one of them tried to change the ownerUserId to a user that doesn't have mobility enabled.
The AXL I'm sending looks like this
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.5"><soapenv:Header/><soapenv:Body><ns:updateRemoteDestination sequence="1"> <destination>00767777777</destination><newName>rd_test_updated</newName><newDestination>00767777778</newDestination><answerTooSoonTimer>5000</answerTooSoonTimer><answerTooLateTimer>25000</answerTooLateTimer><delayBeforeRingingCell>10</delayBeforeRingingCell><isMobilePhone>false</isMobilePhone><enableMobileConnect>true</enableMobileConnect><remoteDestinationProfileName uuid="{0E7336F5-05FE-F52A-21C9-0D40A8445F42}">RDP_testing</remoteDestinationProfileName><lineAssociations><lineAssociation><uuid>{D27C7699-D7C6-9C0E-066B-C729898568B8}</uuid><index>1</index></lineAssociation></lineAssociations><timeZone>Etc/GMT</timeZone><ownerUserId>lsste</ownerUserId><singleNumberReachVoicemail>Use System Default</singleNumberReachVoicemail><dialViaOfficeReverseVoicemail>Use System Default</dialViaOfficeReverseVoicemail></ns:updateRemoteDestination></soapenv:Body></soapenv:Envelope>
Then we have the backend doing some DB checks before formulating the update command
2016-07-21 21:21:53,917 DEBUG [http-bio-443-exec-1] servletRouters.AXLAlpha - Request processed by AXIS
2016-07-21 21:21:53,923 DEBUG [http-bio-443-exec-1] axlapiservice.Handler - dbConnector Initialization in handler.java
2016-07-21 21:21:53,923 DEBUG [http-bio-443-exec-1] axlapiservice.Axl - Connection given to current thread
2016-07-21 21:21:53,945 DEBUG [http-bio-443-exec-1] axlapiservice.AXLCallFlow - In begin transaction of AXLCallflow and created pub connector
2016-07-21 21:21:53,945 DEBUG [http-bio-443-exec-1] axlapiservice.Handler - ClassCast Exception Did not Occurs
2016-07-21 21:21:53,945 DEBUG [http-bio-443-exec-1] axlapiservice.Handler - flag is not equal to update
2016-07-21 21:21:53,946 DEBUG [http-bio-443-exec-1] axlapiservice.Handler - select pkid from RemoteDestinationDynamic where Destination='00767777777'
2016-07-21 21:21:53,948 DEBUG [http-bio-443-exec-1] axlapiservice.UpdateRemoteDestinationHandler - 00767777777
2016-07-21 21:21:53,948 DEBUG [http-bio-443-exec-1] axlapiservice.UpdateRemoteDestinationHandler - select t1.moniker from typemodel t1, device t2, remotedestination t3, remotedestinationdynamic t4 where t1.enum=t2.tkmodel and t2.pkid=t3.fkdevice_ctird and t3.pkid= t4.fkremotedestination and t4.destination='00767777777'
2016-07-21 21:21:53,949 DEBUG [http-bio-443-exec-1] axlapiservice.UpdateRemoteDestinationHandler - Select pkid,enablemobility from enduser where userid='lsste'
2016-07-21 21:21:53,952 ERROR [http-bio-443-exec-1] axlapiservice.AXLAPIServiceSkeleton - com.cisco.www.axlapiservice.AXLAPIServiceSkeleton@17f4260
java.lang.NullPointerException
When I ran this last query manually, I saw that enablemobility was false. So... it makes sense that the operation fails. However, I'd argue that the error returned should be something more useful that what is actually being returned:
2016-07-21 21:21:53,963 DEBUG [http-bio-443-exec-1] servletRouters.AXLAlpha - <?xml version='1.0' encoding='UTF-8'?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Server</faultcode><faultstring></faultstring><detail><axlError><axlcode>-1</axlcode><axlmessage></axlmessage><request>updateRemoteDestination</request></axlError></detail></soapenv:Fault></soapenv:Body></soapenv:Envelope>
07-21-2016 12:58 PM
Thanks Stephan...do you know if this returned a different (more helpful) error in previous versions? We can open a defect either way, but would be good to keep the previous error for consistency, if it makes sense...
07-21-2016 01:08 PM
Issue CSCva58593 opened for tracking
07-21-2016 01:42 PM
Good question. I think it was different on UC 10.5 - I seem to recall getting warnings about users not being enabled for mobility. I can't switch back the cluster at this point though to run the unit tests again. But a message about users not being mobility enabled is something I've definitely seen at some point in the past (it could also have been UC 8.5 or 9 though).
07-26-2016 02:39 PM
FYI, the issue CSCva58593 has been resolved in code, tentatively to be included in the 12.0 release. If you are a customer need the fix for this via a CUCM 'engineering special' (limited testing 'patch' release) please open a DevNet ticket or TAC case, respectively, and we can request it be included in the next ES release.
