CloudCenter 4.8.1: Wordpress Application Deployment
I have modeled Wordpress Application and when i try to deploy it, i'm getting the following error message.
-----------------------------------------------------------------------------------Error Message----------------------------------------------------------------------------------
Failed to do service INSTALL, details: StatusComponent [status=2, standardOutMsg= % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 120 483 120 483 0 0 23661 0 --:--:-- --:--:-- --:--:-- 24150 120 483 120 483 0 0 23467 0 --:--:-- --:--:-- --:--:-- 24150 Root dir /usr/local/osmosix/service/apache2 Called Pre-Install for : CentOS Loaded plugins: fastestmirror, priorities, security Loading mirror speeds from cached hostfile * base: centos.exabytes.com.my * epel: epel.mirror.angkasa.id * extras: centos.exabytes.com.my * updates: centos.exabytes.com.my Loaded plugins: fastestmirror, priorities, security Setting up Install Process Loading mirror speeds from cached hostfile * base: centos.exabytes.com.my * epel: epel.mirror.angkasa.id * extras: centos.exabytes.com.my, standardErrMsg=]
My VM is reaching Internet.
Can anyone suggest the solution.
Sheriff
Saurabh Kothari
NAyeemuddin, are you using the default CloudCenter repo or on-prem?
Hi Saurabh,
I'm using default CloudCenter repo. Then wordpress.zip file, sql file are present in FTP server and pointing tha FTP server location in Agent Lifecycle menu.
Sheriff
Can you try to launch a centos VM from CloudCenter and then install apache manually e.g. sudo yum -y install httpd.  This will let us know if your VM can reach out and download and install all packages.
Hi Mohit,
Updates are getting installed manually, but the thing is when I deploy wordpress application the apache2 server and mysql server are not getting installed it seems and resulting the error mentioned above.
