CISCO ISE 2.3 Extreme Switches
Richard Lucht
We have some Extreme switches in our environment and we use Tacacs to authenticate admin access to those switches.  We are phasing out the Tacacs and we are trying to replace the switches as fast as we can.  For the time being the tacacs will be gone before we can get the Extremes replaced.  We are using Cisco ISE to authenticate access into our Cisco and Juniper switches.  We would like to try using ISE to access Extreme switches.  I have on my lab desk that I am using our test ISE vm to set up access into the switch.  I am trying radius first then tacacs.  Has anyone tried this before and have they been successful?  Looking for some guidance.
Craig Hyps
Level 10
Level 10
Yes, there are different teams that have tested Extreme.   Features and support depend on the switch capabilities.  Many of the Extreme switches do not support RADIUS CoA, so for flows that require CoA you must rely on SNMP CoA. Be aware of
CSCvd06733Need to support Extreme switch SNMP CoA with ISE
If RADIUS CoA is not an option and CoA is required, there is plan to address via a patch but would require TAC to obtain.
Craig
Craig Hyps
Level 10
Level 10
Craig
I was able to configure a dictionary and result in Cisco ISE 2.1 and 2.3 and then create and authorization policy that gave me the results that I was looking for.  I was able to configure all the Extreme switches we have to use radius and authenticate with ISE.  thanks
Glad to hear.  Please feel free to share whether you tested flows that rely on CoA and method used.  You can also publish your NAD profile per instructions here: ISE Third-Party NAD Profiles and Configs
