help, error connection Cisco Identity Services Engine with AD.
JERRI -
Dear all,
I have Cisco Indentity Services Engine, that  connected to Active Directory. When I test connection detailed,
the result is error, said:
Test Connection Results
This dialog shows the detailed logs for the operation for: idsv0018.
Status: FAILED: Global Catalog port status error.
Can anyone help?
I believe,  because this error, I can't search group of AD, at Cisco ISE.
FYI: the connection from Cisco ISE to AD, joined with successful result.
Jerri
11 Replies 11
Leo Laohoo
Duplicate posts.
Ravi Singh
Level 7
Level 7
Yes leolaohoo is correct this error occur due to duplicate port. Please check the port setting.
Hi Ravi,
Where i should check my port setting?
fyi,
leolaohoo said duplicate post, not duplicate port.
thks,
Jerri
Jatin Katyal
Can you do nslookup from the ISE CLI.
Was this working before and you rebooted your GC and after that you started seeing issue.
In your DNS settings can you see global catalog in the Forward Lookup Zone?
Jatin Katyal
- Do rate helpful posts -
~Jatin
Hi Jatin,
Thanks for the reply.
yes, we can do nslookup from ise cli.
this problem already appear from the first time i try to test detail  AD from CISE.
I can't retreive group of my AD, because of this.
where section, that i can see my global catalog in my DNS windows server?
Thks,
Jerri
do anyone having a same problem when integrating AD multidomain with Cisco ISE?
askhuran
Hello Jerri,
Please follow these steps:
1.    Make sure that ISE can connect to the Global Catalog (by Default  it is Domain Controller) on the following ports (see table below)
2.    Check Windows Event Viewer > System Events on your Domain  Controller and locate any errors / warning. Note down Event ID
3.    If there are any errors, other client computers in your AD domain  are likely to experience problems locating User groups, Printers etc.
4.    If the above steps are confirmed, then you need to fix  .msdcs.ad-domain.xyz and the records, on your primary DNS (Master Domain  Controller by default)
5.    To fix those records, you may refer to the following link for more  guidance on how to do it. Or your Windows AD Administrator should  fix it
How DNS Support for Active Directory Works
http://technet.microsoft.com/en-us/library/cc759550
Otherwise let me know about the detail on Event IDs you notice in your Windows Event Viewer
Service Name
UDP
TCP
LDAP
3268 (global catalog)
LDAP
3269 (global catalog Secure Sockets Layer [SSL])
LDAP
389
389
LDAP
636 (SSL)
RPC/REPL
135 (endpoint mapper)
Kerberos
88
88
DNS
53
53
SMB over IP
445
445
1. telnet from cise to AD server with port (all port in the table), can connected.
2. no error related to AD in the system events
3. users can locate printer, and others objects in the AD, and no problem with login (if GC problem, i think, login to domain, will also be problem)
4. DNS server
there is _gc (SVR type) in the
.msdcs.ad-domain.xyz -> gc -> sites -> name of the sites -> _tcp
But no_gc file (SVR type) in the
ad-domain.xyz at DNS server. folder _tcp.
so, i making this files.
But, still can't connect / find the GC / GC port status error , when detailed test in the Cisco ISE.
FYI, we have multiple domain in this company.
Didn't know what could be the problem, but
do you guys know how to repair GC in the AD?
It's clears that when ISE tries to find the GC using the _gc._tcp. DNS query. It doesn't find that information on the Domain controller. The GC information is missing on the DC.
_
gc._tcp.DnsForestName
Allows a client to locate a Global Catalog (gc) server for this domain.
Jatin Katyal
~Jatin
