Recommended values for synflood and rate limiting
JP_Berlin
Hi community,
I have two questions regarding the ISE CLI commands synflood-limit and rate-limit:
  1. I do understand the use case for synflood-limit since a high number of TCP-SYN is a clear indication for a malicious attack. But what about the use case for rate-limit? ISE inter-node communication? Communication with integrated 3rd party devices (for example through pxgrid)? Or even access to the ISE portals (Guest, Sponsor...)? I would appreciate if someone shed some light on this.
  2. And finally I am looking for recommended values for the synflood-limit and rate-limit commands (in terms of packets per second). In other words: are there any guidelines on how to avoid an impact on ISE operations.
Cheers!
hslai
Such settings could impact authentication TPS; especially EAP-TLS. Please use them with cautions.
The command synflood-limit takes only a numeric value as the argument so it applies to all TCP attempts. A similar command "conn-limit" takes ip and port arguments so give us more choices if we are to implement sync flood protection on TCP connections. The other command "rate-limit" also take ip and port arguments but it applies to all TCP/UDP/ICMP.
hslai
Hello, hslai
I would like to know if maybe you know what is it the recommended rate for configuring with the command "rate-limit" for TCP/UDP/ICMP.  Right now I'm hardening an ISE deployment, and I've been following this guide https://community.cisco.com/t5/security-documents/ise-security-best-practices-hardening/ta-p/3640651 but I don't know what value the rate limit has to take.
Thank you so much in advance.
