Replace ACS 5.8 with ISE for PPPoE auth
nzerth
Customer is currently using ACS 5.8 and does PPPoE Authentication for his 800er Cisco Routers via ACS. Can this functionality be achieved with ISE?
ldanny
Here are some attribute values you might want to focus on your NAD and run a sniffer or a tcp dump from ISE .
Extended NAS-Port-Type and NAS-Port Support - Cisco
7 Replies 7
ognyan.totev
Level 5
Level 5
Device
Validated OS 17
AAA
Profiling
BYOD
Guest
Posture
MDM
TrustSec 18
Minimum OS 19
Cisco Routers
ISR 88x, 89x Series
IOS 15.3.2T(ED)
X
X
X
IOS 15.2(2)T
X
X
X
Maybe this will answer you.
Best regards.
thanks a lot for the response, but this does unfortunatley not answer this question. The question is more if ISE is able to authenticate PPPoe-Connections at all (I don't know if such an authentication request contains special RADIUS attributes which are probably not supported by ISE)....
Researching !
nzerth
Hey guys,
any news on this topic?
Thanks a lot for your support!
hslai
Supposedly the existing PPPoE using ACS as RADIUS servers, then ISE should work the same.
I would suggest to check the existing configuration for this in ACS and try migrating it to ISE in a lab setup.
ldanny
Hi all,
thanks a lot for the responses. Will check with the customer this week.
Roland
Roland Mueller
CONSULTING SYSTEMS ENGINEER.SECURITY SALES
rmueller@cisco.com<mailto:rmueller@cisco.com>
Tel: +49 711 2391 1306
Cisco Systems, Inc.
City Plaza - 4th Floor Rotebuehlplatz 21-25
STUTTGART
70178
Germany
cisco.com
Think before you print.
This email may contain confidential and privileged material for the sole use of the intended recipient. Any review, use, distribution or disclosure by others is strictly prohibited. If you are not the intended recipient (or authorized to receive for the recipient), please contact the sender by reply email and delete all copies of this message.
Please click here<http://www.cisco.com/web/about/doing_business/legal/cri/index.html> for Company Registration Information.
