03-01-2023 05:31 AM - edited 03-01-2023 05:32 AM
Solved! Go to Solution.
03-01-2023 06:21 AM
1. try using console connection. and if that also password protected which you dont know, go to step2.
2.https://www.cisco.com/c/en/us/support/docs/routers/2800-series-integrated-services-routers/112033-c2900-password-recovery-00.html - here you can bypass existing configuration at bootup process and do required changes and save.
03-01-2023 06:21 AM
03-01-2023 06:52 AM
It is not clear what the issue is or what about ssh is an issue. Perhaps telnet might be an option for accessing the router? I agree that access via console is a good option and as a last resort password recovery.
03-01-2023 08:30 AM
My problem is that the configuration I restored contains enable password and I don't have this password, so I cant login to my router,I just want to reset my router or bypass the configuration
03-01-2023 09:57 PM
Thanks for the clarification. In this case what you need is the password recovery procedure
