Interface status change and show interface descritpion
geevee1989
Hi All,
I am trying to write a script which will mail the status change along with " show inter description" details.
event manager applet interface-down
 event syslog severity-notification pattern "%LINEPROTO-5-UPDOWN: Line protocol on Interface.* changed state to down"
 action 1 regexp "Interface ([^,]+)" "$_syslog_msg" match intf
 action 1.1 cli command "do show interface $intf description"
 action 2 mail server "$email_server" to "$email_to" from "$email_from" subject "Interface status change" body "Interface $intf changed state to down $_cli_result"
end
Issue is ,am not getting the " show inter description". can someone help me on this?
Thanks in Advance
Geevee
Dan Frey
Before action 1.1 EEM needs to issue the "enable" command.
Dan Frey
Thanks Daniel, that worked
