Forwarding Netbios names over point-to-point connection and Pix
denizpecel
Dears
We have two networks connected over ADSL point-to-point connection(actually one side is MetroEthernet). Lets say A and B networks. On both sides there are Pix 501 and Pix515 respectively. There are computers located in A with i.e. 10.0.0.1/24, 10.0.0.2/24.. And in network B there is also a computer with the same subnet configuration. (i.e. 10.0.0.3/24), all computers do not have gateway addresses congfigured and they try to communicate each other over NetBIOS. So What i need to try is to connect the PC in B to A over this firewalls. Please note that it is almost impossible to change IP configuration of PCs. Is this possible??
Best Regards,
Deniz
wong34539
Level 6
Level 6
What version of software does your pix box run?
6.3.1 and 6.3.5
best Regards,
Deniz
As far as I know 6.x will not support the transparent firewall feature from 7.x.
The way to do it is with routers and GRE tunnel.
Please rate if this helped.
Daniel
