Calls are disconnected after a while; after been transferred from operator in B-ACD
jesusjimenez1
Hi everyone!
I have  a problem  with Cisco CME 12.0 and B-ACD feature. The AA is working fine, but when a customer pass to talk with an operator and ask to be transferred with another extension the call is dropped after a silence. Do you have any advice?
My config to AA:
application
service aa flash:app-b-acd-aa-3.0.0.5.tcl
  paramspace english index 1
  param number-of-hunt-grps 1
  param handoff-string aa
  param dial-by-extension-option 1
  param operator 1000
  paramspace english language en
  param max-time-vm-retry 2
  param aa-pilot 6000
  paramspace english location flash:
  param second-greeting-time 30
  param welcome-prompt _bacd_welcome.au
  param queue-manager-debugs 1
  param call-retry-timer 20
  param max-time-call-retry 700
  param voice-mail 6050
  param service-name queue
service queue flash:app-b-acd-3.0.0.5.tcl
  param queue-len 5
  param aa-hunt10 1000
jesusjimenez1
Well, if someone is getting this kind of problem, I solved recently.
Problem was an interoperability between H323 (B-ACD is based in H323) and SIP protocol (all of my phones are based in SIP).
Luckly, Release 11.6 onwards, BACD supports line side call from SIP, SCCP, FXS phones but you need to configure a loopback voip dialpeer (SIP) with codec g711ulaw, DTMF rtp-nte, and a proxy B-ACD pilot number as the destination pattern. Also you need to change the proxy destination pattern to actual B-ACD pilot number before sending out the call invite. You can achieve this using either voice class sip-profiles or translation rules.
Note: I used translation-rule to change the proxy, thats  'cause when the incoming call is showed in the display of end user it's show the 1234 number in the example, in the translation-rule you can transform this in the original incoming number.
Example using sip-profiles:
voice class sip-profiles 1
request INVITE sip-header SIP-Req-URI modify "6001@" "6000@"
request INVITE sip-header To modify "6001@" "6000@"
request INVITE sip-header From modify "<sip:(.*)@" "<sip:1234@"
request INVITE sip-header Remote-Party-ID remove
#dial-peer voice 1 voip
destination-pattern 6001
session protocol sipv2
session target ipv4:1.0.0.1
voice-class sip profiles 1
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 2 voip
service aa-bcd
incoming called-number 6000
dtmf-relay rtp-nte
codec g711ulaw
Example using Translation-rule:
translation-rule 1
Rule 1 6001 6000
Rule 2 7001 7000
translation-rule 2
Rule 1 * 6666
translate-outgoing calling 2
translate-outgoing called 1
dtmf-relay rtp-nte
codec g711ulaw
service aa-bcd1
dtmf-relay rtp-nte
codec g711ulaw
jesusjimenez1
dtmf-relay rtp-nte
codec g711ulaw
service aa-bcd
dtmf-relay rtp-nte
codec g711ulaw
translation-rule 1
Rule 1 6001 6000
Rule 2 7001 7000
translation-rule 2
Rule 1 * 6666
dtmf-relay rtp-nte
codec g711ulaw
service aa-bcd1
dtmf-relay rtp-nte
codec g711ulaw
