DLU Licensing
Hi, We are having CUCM 5.x and i want to order additional Device License for 7911 phone, and required 60 units. Can some help with part number to purchase device license for 60 Units which supports 5.x CallManager.
Thanks in advance
MAC
Regards MAC
5 Replies 5
Wilson Sy
Hello Mohammed,
DLU's are not version specific,  you can use Top Level part number LIC-CM-DL to purchase additional DLU's.
Best Regards,
Wilson
Thanks Wilsy
kindly i have same case need to buy license for the following Phones with different numbers to work on Cisco call Manager version 7.1:
  1. CP-7975G  --> QTY70
  2. CP-7965G --> QTY100
  3. CP-7942G--> QTY 150
  4. CP-7916= --> QTY100
  5. CP-9951-C-K9 --> QTY50
please advise with license or DLU part number can buy to add the above number of IP phones on CM 7.1.
thanks,
Hi Sally,
You can use the same top level part number to order the DLU's needed "LIC-CM-DL".  The expansion module CP-7916 does not require a license.
If you have CM 7.1.5 you do not need to order DLU's but you will need the Enhanced license instead. You need to use top level part number L-CUCM-USR-LIC-ADD and select Enhanced license. The licensing scheme will be per device (70 CP-7975G = 70 Enhanced license).
Best Regards,
Wilson
Pre-Sales Specialist
Global Virtual Engineering
Hi Wilson,
Using c2951-CME-SRST/k9- with CP 7951 other 8 series and 9 series of Cisco Phones. How many DLU will I require per device. Can you guide me please.
Hi Fida,
Apologies for the late response. what version of CME are you using?
Best Regards,
Wilson
