What happens to L2 Protocols when a tunnel is not terminated?
shane1022
Howdy, I have a quick questioning that I can not seem to find an answer to.
If I have a UNI port that is configured for dot1q tunneling, and the other side of the circuit is not, what happens to the layer 2 protocol packets? If L2P packets get encapsulated when do they get de-encapsulated if the tunneling command is not on the remote end? Do they just get dropped?
Test topology
CustomerDevice-----------NID(dot1q tunnel)--------Router(IP interface into a private l3vpn)
Thanks.
grerose
Level 6
Level 6
Hi Shane,
This question might be better to post in the Cisco Support Community. I see there is some discussion going on over there about Layer 3 Protocols. Not sure it this is relevant to you, but it might be a good place to start.
Solved: Tunneling VLAN though L3 - Cisco Support Community
Thanks!
Greg Rose
Cisco Community Manager
