03-27-2024 09:17 PM
1. Make end to end connectivity first.
2. Block the network for these site
1)Make sure that Site 4 will not advirtise any network to Site 5 which it receiving from Site3 routers.
2) On site 5 , when we check routing table of R2 router, it dont have network of Site3 routers.
ping 147.147.21.1 should be deny and
ping 147.147.21.37 should be reachable.
03-28-2024 09:17 PM
You're asking for really broad help. Have you started this and are stuck somewhere that we can possibly assist with?
03-28-2024 09:30 PM
I stuck at router 6 when I am assigning router 6 with area 0 then it's working fine but when I am doing again it with area 37 then it's throwing error of I'd mismatch and continuously it's throwing error in a loop
03-28-2024 09:45 PM
Can you post your config from R6?
03-28-2024 10:30 PM
See this console and tell what command should I write here after router ospf 1
03-28-2024 10:46 PM
According to your diagram you should be putting "network 147.147.21.36 0.0.0.31 area 37" following your pattern. It might be more clear if you put the network IDs instead of the interface IPs but either will work.
03-28-2024 10:50 PM
Actually I am new in this field and I don't know much about this and I am trying to solve this from 2 days but I didn't get anything. One of my friend told to use GRE tunnel to solve this but I don't know about it. Can you please send me the commands if possible.
03-28-2024 10:53 PM
Did you try the last command I sent?
03-28-2024 11:13 PM
I wants to ask you that I should not write 0 at last bit for every router network address?
03-28-2024 11:24 PM
No, if you do that then they'll all be the same network and the router won't let you.
03-29-2024 12:57 AM
Now it's not throwing error but i don't know whether I am doing right or not according to the question. Can you guide
03-29-2024 01:35 AM
What's your next goal?
03-29-2024 01:46 AM
Now I have to make sure site 4 does not advertise to any Network to site 5 which it's receiving from site 3 routers so now I have to block these networks so what command should I use?? Because when I am pinging 147.147.21.1 from Site 5 it's giving me reply but I have to block it and my ping of 147.147.21.37 from site 5 is working fine
03-29-2024 01:53 AM
I think you can do that by making two different OSPF processes on R5. One of them will be for area 0. One of them will be for Area 99. Then don't redistribute them into one another.
03-29-2024 02:28 AM
Can you give me the command for this for R3 and R4?
