Catalyst C8200 1RU w/ 1 NIM slot and 4 x 1-Gigabit Ethernet WAN ports - SFP Ports
wjlawrence
We are looking at a large rollout of Cisco C8200 1RU w/ 1 NIM slot and 4 x 1-Gigabit Ethernet WAN ports.  We need three operational copper 1G ports.
I can not find any recommendation on support for copper 1G (GLC-TE=) for this product.  Can someone point me in the correct direction.
Thank you for your assistance.
Bill Lawrence
pieterh
from the datasheet:
Integrated Gigabit Ethernet ports
●  Provides four built-in Ethernet WAN ports
●  Platform features two Ethernet ports in Small Form-Factor Pluggable (SFP) and two RJ45 ports, enabling for fiber as well as copper connectivity.
although no reference to 1G (GLC-TE=)  I guess it will be supported
other option is a NIM
LAN modules
NIM-ES2-4
Cisco 4-port Gigabit Ethernet switch NIM
NIM-ES2-8
Cisco 8-port Gigabit Ethernet switch NIM
NIM-ES2-8-P
Cisco 8-port Gigabit Ethernet switch NIM with PoE support
you can find out the all products of Cisco at Greenway Enterprise
