Zone problem between storage and blade
adam900331
Hy!
I have Cisco SAN switch (DS-C9132T-K9). I created some zone for the standalone servers and storage. And also create zones for my blade and storage. I have 3 blade server:
ESX1 pwwn: 50:01:43:80:02:a4:90:00
ESX2 pwwn: 50:01:43:80:02:a4:90:04
ESX3 pwwn: 50:01:43:80:02:a4:90:08
Storage pwwn: 24:70:00:c0:ff:28:cc:a5
The zones configuration for the blade:
zone name ESX1_MSA1 vsan 101
member pwwn 50:01:43:80:02:a4:90:00
member pwwn 24:70:00:c0:ff:28:cc:a5
zone name ESX2_MSA1 vsan 101
member pwwn 50:01:43:80:02:a4:90:04
member pwwn 50:01:43:80:02:a4:90:08
I activated the zoneset, but unfortunatelly the servers couldn't see the storage.
The connection between the standalone servers and storage works correctly. What is the different If I create zone for blade servers?
Thanks.
adam900331
The zone problem is resolved, I modified the zone configuration and forget to activate the zoneset. After I activated the zoneset, the affected host and storage communication works.
6 Replies 6
marce1000
 - You have  two zones named  ESX2_MSA1 ; is that intended , or a typo ?
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
Sorry, I wrote it wrong. The coerrect zone name is:
zone name ESX3_MSA1 vsan 101
  - Remember to activate the zoneset if applicable with : zoneset activate....
  - Check flogi status with :  show fcns database ...
  - Verify active zones using :  show zone active ...
  - Check logs on the SAN switch  with : show logging
 M.
Thanks.
I see all connected device which is part of the zone config.
Can I check the unzoned devices WWNs? I run the following comman: sh zone analysis active
And I see there are 5 unzoned devices:
Number of devices zoned in vsan: 45/50 (Unzoned: 5)
And also checked the following command: sh zone internal event-history errors
There are some error which is regarding the port where the affected blade and the storage is connected:
2024 Jan 16 22:36:22.150049: E_DEBUG [181] mts_drop:2985 proc(/isan/bin/zone_server) errno(22) msg_ref does not have valid msg payload
2024 Jan 16 22:36:22.150018: E_DEBUG [181] ref_payload_get(/isan/bin/zone_server) Invalid payload/mtsbuf(0xf4f0d404) found
2024 Jan 16 22:36:22.147724: E_DEBUG [110] zone [4517]: Lc entry for fc1/2 at slot 0 not found
2024 Jan 16 22:36:22.147690: E_DEBUG [110] zone [4517]: Lc entry for fc1/4 at slot 0 not found
2024 Jan 16 22:36:22.147644: E_DEBUG [110] zone [4517]: Lc entry for fc1/6 at slot 0 not found
2024 Jan 16 22:31:09.786449: E_DEBUG [181] mts_drop:2985 proc(/isan/bin/zone_server) errno(22) msg_ref does not have valid msg payload
2024 Jan 16 22:31:09.786424: E_DEBUG [181] ref_payload_get(/isan/bin/zone_server) Invalid payload/mtsbuf(0xf4f0d404) found
2024 Jan 16 22:31:09.784361: E_DEBUG [110] zone [4517]: Lc entry for fc1/4 at slot 0 not found
2024 Jan 16 22:31:09.784313: E_DEBUG [110] zone [4517]: Lc entry for fc1/8 at slot 0 not found
2024 Jan 16 22:24:58.526362: E_DEBUG [181] mts_drop:2985 proc(/isan/bin/zone_server) errno(22) msg_ref does not have valid msg payload
2024 Jan 16 22:24:58.526337: E_DEBUG [181] ref_payload_get(/isan/bin/zone_server) Invalid payload/mtsbuf(0xf4f0d104) found
2024 Jan 16 22:24:58.524075: E_DEBUG [110] zone [4517]: Lc entry for fc1/4 at slot 0 not found
2024 Jan 16 22:24:58.524023: E_DEBUG [110] zone [4517]: Lc entry for fc1/2 at slot 0 not found
2024 Jan 16 22:24:58.523961: E_DEBUG [110] zone [4517]: Lc entry for fc1/18 at slot 0 not found
2024 Jan 16 22:15:44.811695: E_DEBUG [181] ref_payload_get(/isan/bin/zone_server) Invalid payload/mtsbuf(0xf4f0d504), snode/msgid (mtsbuf:102/b43bd12) (msg-ref:101/2609c09)
I don't know what does it mean. We connected the devices to the switch with the logs timestamp.
Thanks.
adam900331
Do you have any idea?
adam900331
